Question about Vehicle Parts & Accessories
How to take nahrled4 car remote out of valet mode
2 Suggested Answers
  • 63 Answers
SOURCE: Remote strater is in valet
Try these two possible solutions
Press and hold valet button for 10 seconds. Release. LED should go out.
or
Insert key into ignition. Turn to on position (do not turn on car). Press and hold valet button for 10 seconds. Release. LED should go our
Posted on Jan 04, 2011
VALET MODE DISPLAY ON THE CLUSTER
go to the trunk of the car and put the key into the trucnk tumbler and open it, that will deativate the valet mode...
Jan 10, 2014 | 2006 Jaguar XK8
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Issue with 2 way FCC NAHRLED4 05-A remote starter starting on its own???
It could be something as simple as a loose connection, or a bad brain. Have a tech look at it. Not something I would reccommend for the do-it-yourselfer. You could really damage a critical component in your vehicle.
Mar 01, 2012 | 2005 Ford Focus
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
Remote strater is in valet mode and i do not know how to get it out of valet made.
or
Jan 04, 2011 | 533 2way Security Remote Start System
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
Remote Car starter won't work
put your key in the ignition, then remote start it, if it starts, you need to either move the transponder loop of key or reprogram the transponder or take it to a remote starter shop
Jan 13, 2010 | 2003 Honda CR-V
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Oct 15, 2007 | Viper RCVGC022 Remote Control
Vehicle Parts & Accessories Logo
191 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
