Question about iLO Televison & Video
Where is a 8 digit setup key on my tv?
I need to look for a 8 digit setup key
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
  1. Turn on your TV
  2. Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
  3. On the Comcast remote, press and release the TV key
  4. On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
  5. On the Comcast remote, enter the first listed five digit code
    Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
  6. Aim the remote control at the TV and press the POWER key once
  7. The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Nov 03, 2013 | Apex Digital DT502
Need codes for philips universal remote to program to a deawoo tv
Hello
There is no set up code described in the manual of your remote control. But you can find out the code that stored in your device with this remote control handset. For that do the following.
The Code Identification Feature allows you to identify
the 4 digit library code stored under your device key. For
example, if you want to find out what 4 digit code is
stored under your TV device key, follow the six steps
below:
1. Press and hold the SETUP button until the red
indicator stays on. Release the SETUP button.
2. Press and release the desired mode button (TV,
VCR, etc.). The red indicator blinks, then stays lit.
3. Press and release the SETUP button. The red
indicator blinks off.
4. To find the first digit for the code stored under the
mode key pressed in step 2, press each numeric key
from 0-9 in turn. When the red indicator blinks off
the number you pressed is the first digit for the code
you are searching for.
5. To find the second digit, repeat step 4, this time
when the red indicator blinks off this is the second
digit.
6. Repeat step 4 to find the third and fourth digits.
Write these digits in order and you will get the code of your device.
Direct code entry mehod.
indicator stays on, then release the SETUP button.
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the red
indicator flashes.
4. With your device on, press CHANNEL UP. If the
device responds, no further programming is required.
Note: If some buttons do not operate your equipment,
try one of the other codes for your brand.
OK.
Feb 19, 2011 | Philips SRU3003 Remote Control
What are the comcast remote codes for Sony HT-SS370 home theater system?
If you have this comcast Universal Remote - Red OK/Select Button here are the codes Sony 11100, 10000, 11317
if this doesn't work use the search mode
Searching For You our Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Checkcking the Codes
If you have set up the remote control using the Searching For Your Code
procedure, you may need to find out which five-digit code is operating your equipment. Perform the following steps after setting up your devices to find out which five-digit code operates your equipment. For example, to find out which code is operating your TV:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 0. The TV key will blink twice.
4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks =3) and write down the number in the left most TV Code box (at end of this section).
NOTE: If a code digit is "0", the selected mode key will not blink.
5. Repeat step 4 four more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the fifth digit. Finish writing down the code in the TV Code boxes (at end of this section).
It can be a pain but once you get it down its a cake walk.
Jan 23, 2011 | RCA L42FHD37 42 in. LCD HDTV
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Jun 01, 2010 | Symphonic SC3919 Combo
Need the code so that I can program my Direct TV
I just checked online at DirecTV and searched your Astar TV. This is the result I got...
"There is no setup code indicated for your product.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key. "
Feb 11, 2010 | Astar LTV-3001 Television
Need tv code for Quasar LSSQ0227 its a comcast
had this problem myself and I assure you that a) Comcast is populated by idiots without training, and b) that Quasar hasn't 'deliberately designed' their tvs to not work with Comcast remotes, which is what Comcast will tell you.
Solution: Add a 1 to the code, ie 10250, 10051 etc. Quasar is a 5 digit code, not 4 as Comcast believes.
Feb 06, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Tv code
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Enter the 5 digit Code above.
  • Try the volume and power button to tset the code
  • 2 possible codes for Element TV, 10835 and 10178.
    If that doesn't work, you can try searching through all the codes stored in the remote. Here's how you do it:
      1. for Televisions
    May 28, 2009 | Televison & Video
    URC-3605B1 need code for insignia tv
    If your device does not respond to the
    remote control after trying all codes
    code. For example, to search for a code
    for your TV:
    1. On the remote control, press TV once.
    2. Press and hold SETUP until the LED
    blinks twice, then release SETUP.
    3. Enter 9 - 9 - 1.The LED will
    blink twice.
    4. Aim the remote control at the the
    TV and slowly alternate between
    pressing POWER and TV. Stop when
    the TV turns off.
    5. To lock in the code, press and hold
    SETUP until the LED blinks twice,
    then release SETUP.
    6. To search for the codes of your other
    devices, repeat steps 1 through 5, but
    substitute the appropriate device key
    which four-digit code is operating your
    equipment:
    operating your TV:
    3. Enter 9 - 9 - 0.The LED will
    blink twice.
    press 1 once.Wait 3 seconds, count
    the LED blinks (e.g., 3 blinks = 3)
    and write down the number.
    NOTE: If a code digit is “0”, the LED will
    not blink.
    5. Repeat step 4 three more times for
    remaining digits.Use 2 for the
    and 4 for the fourth digit.
    6. To check for codes of other devices,
    repeat steps 1 through 5, but substitute
    the appropriate device key for
    each device you are checking.
    As before,write down each fourdigit
    code.
    http://www.rockabilly.net/files/manuals/URC-3605.pdf is my source for the info
    http://www.rockabilly.net/files/manuals/URC-3605-codes.pdf these are the codes, I didn't see insinia in the TV section, so you may have to use the search feature
    May 11, 2009 | One For All URC-3605 Remote Control
    Tv/dvd codes
    1. Turn on your TV.
    3. Enter 9- 9- 0. The TV key will blink twice.
    4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks = 3) and write down the number in the left- most TV Code box (at end of this section).
    Note: If a code digit is "0", the selected mode key will not blink.
    Repeat step 4 three more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, and 4 for the fourth digit.
    May 01, 2008 | TruTech PLV16190 Television
    Televison & Video Logo
    256 people viewed this question
    Top iLO Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Radames Pagan
    Radames Pagan
    Jaime Hernandez
    Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
