Question about Sony PFM-42V1 42 in. HD-Ready Plasma Television
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of the top
Hello Shaundolphin, I've seen you posting useful information for other users on this website and that you have lots of experience with Sony plasma TVs. I am technically capable, able to repair the boards but I need to be pushed in the right direction so I was hoping you can help me fix my TV.
My Sony PFM-42V1 looks ok on the upper half of the screen but the lower part will display an image that is a blurry ghost image of the top half. I opened the unit and found capacitor C12 (47uF, 350V) on the ZSUS board blown up. I replaced that capacitor and turned on the unit. The problem was still there and after about 30 min of work, I noticed that a crack showed up on the side of the new capacitor I've put in and that the heatsinks of IC4 (on ZSUS board) and IC12 (on YSUS board) were extremly hot.
I've used a multimeter to check the pins of these 2 ICs, the transistors, diodes and fuses on the ZSUS and YSUS boards but I didn't find anything suspicious.
Please let me know what else I should check/replace or anything else that you might need to diagnose the problem.
Thank you.
  • georgetell01 Oct 26, 2008
    Hello, still hoping to get some help with the problem posted above or if the paid service would have a solution for it...
    Thank you
2 Suggested Answers
quang123
  • 107 Answers
SOURCE: Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Posted on Dec 11, 2008
Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
Jul 02, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
My sony pfm-42v1 no pictue
turn it off for around 30 min..try it again, then let us know what you find...could be a control board issue
Apr 27, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Mar 08, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Cannot even find where to plug to aerial point into the sony plasma flat panel display tv PFM-42V1
PFM-42V1 has no ability to receive channels through aerial / cable.
You can hook direct video cables from dvd player, vcr, PC etc.
Dec 07, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I am having two problems with my Sony PFM 42v1 TV monitor.  The first problem is that it is having that double-image that other people have posted about.  That is, the top half of the screen is basically...
I suspect you have a SUS board failure, but it may be worse than that. What it sounds like is the SUS board that drives the bottom half of the panel has failed, but the problem may not end there. The only way to know is to replace the defective SUS board (Y SUS) and possibly the Y DB (driver board). The real possiblilty exists that you may have a bad plasma panel as well, but the only way to tell is to replace the Y SUS and Y DB boards first and see what happens and what you have. The repairs are DEFINITELY NOT something an average consumer should attempt, as there are adjustments that must be done after replacing the boards and the very real possiblity of ELECTRICAL SHOCK exists. I wish I had better news for you; please don't rate me poorly for giving you the correct information.
Nov 28, 2008 | Televison & Video
Oct 22, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
