Question about Traxxas Flywheel Nut- TRA5244
I need a 99 ford f 150 manual on how to fix the flywheel and how to drop the transmission
The nut is missing
  • 273 Answers
You could pick up a haynes manual at most local parts stores or even on e-bay, should cost about 15 dollars.
Posted on Feb 08, 2012
Can 2008 ford f350 6.4 crank without transmission?
strange question
as to think why the transmission would be missing
motor will crank with the starter motor if transmission has failed
automatic transmission has a neutral safety switch
if that is faulty the starter may not crank
if a stand alone motor
starter motor will need to be bolted on and spaced to match the flywheel teeth
spacing has to be exact replacement for the missing gearbox housing thickness
Nov 24, 2016 | Ford Cars & Trucks
99 cadillac deville flywheel replacement
1979 Cadillac Coupe 425 engine running; flywheel knocking
? 1:16
https://www.youtube.com/watch?v=UTDBmkKyBCY
Sep 30, 2011 - Uploaded by Edgar H
1979 Cadillac Coupe 425 engine running; flywheel knocking ...Change Transmission Fluid pan removal Cadillac Seville part1 - Duration: .
Exclamation Re: Found a 94 STS for $800, needs flywheel ...
www.cadillacforums.com/.../cadillac-seville-cadillac.../65815-found-94-s...
Feb 16, 2006 - 15 posts - ‎9 authors
Cadillac Seville / Cadillac Eldorado Forum Discussion, Found a 94 STS for $800, needs .... If it is somehow just the flywheel, your repair cost would be the labor involved in dropping ... Automobile(s): 1999 STS - diamond white. Re: flywheel 99 sts
Apr 7, 2013
Re: need to replace flywheel
Dec 3, 2011
Re: Location of transaxle to engine bolts on 1998 ...
Nov 13, 2011
Re: How to lock flywheel without $150 tool?
May 21, 2009
More results from www.cadillacforums.com
Jan 11, 2016 | Cadillac Cars & Trucks
How to install flywheel ford f150 6 cylinder engine
Pull drive shaft 4 bolts next pull transmission cross member 4 bolts pull transmission lines 2 pull all wiring 2 pull transmission inspection cover 4 bolts pull transmission 6 bolts pull flywheel 6 bolts install new and reverse process
Aug 12, 2014 | 2005 Ford F-150 SuperCab
Automatic transmission removal
Derrick, yes those bolts must be removed in order to separate the transmission from the flywheel. You can turn the motor clockwise from the bolt that holds in the harmonic balancer in the front of the motor. Use a prybar or flywheel tool, if needed, to hold the flywheel stationary while removing the bolts with a wrench. Careful not to damage teeth on flywheel...DW
Apr 08, 2014 | 2003 Ford Escape
Can't remove my stick
Pull the shift boot up there you will see a 17 mm screw and nut take the nut out and thread it on the other side of it start tightening in down and it will pull the shift stick out
Nov 15, 2012 | 1989 Ford F 150
HI there. I need to know how to remove torque converter from 1999 ford f-150 truck
Welcome to Fixya
On the front of the transmission is a removable cover that allows access to the four torque-converter nuts holding the torque converter to the flywheel. Used a bump starter to turn the engine over so he could rotate the torque converter and access all of the nuts. After you remove the nuts, remove the six bellhousing bolts that hold the transmission.
Thank you of using Fixya!
Jul 27, 2011 | Computers & Internet
Looking for torg specs on tire lug nuts on a 15passenger van f350
Hello there
FORD TRUCK
Wheel Nut Torque Specifications
Make/Model Description Years Torque Make/Model Description Years Torque
FORD (continued)
FORD TRUCK
E250 Van 8 Lug, 9/16" 2008-88 140 -160 ft lbs
E350 Van 8 Lug, 9/16" 2008-88 140 -160 ft lbs
Escape - 2003-01 98
Excursion - 2003-01 160
Excursion - 2000 148
Expedition - 2003-01 150
Expedition 19mm Hex 2000 100
Expedition 21mm Hex 2000 150
Expedition - 1999-97 100
F Super Duty Pickup 10 Lug, 9/16" 2003-99 165
F Super Duty Pickup 10 Lug, 9/16" 1998-96 140
F150 Pickup - 2003-01 150
F150 Pickup 19mm Hex 2000 100
F150 Pickup 21mm Hex 2000 150
F150 Pickup - 1999-88 100
F250, F350 Pickup 8 Lug, 9/16" 2003-01 160
F250, F350 Pickup 8 Lug, 9/16" 2000-99 148
F250, F350 Pickup 8 Lug, 9/16" 1998-88 140
Ranger, Windstar - 2003-87 100
Feb 01, 2011 | 2008 Ford F-350
Problem with removing transmision on '72 Ford F100
Yes you have to remove the plate and the four nuts that hold the TC in the vehicle. You can damage the pump and the TC hub leaving on the flywheel. Also when the time comes to put the replacement in you have to align the TC into the pump of the trans, you can't do that if it is hooked up to the flywheel.
Remove the shield and use a remote start to turn the flywheel around to each nut. You can also use a pry bar pushing on the teeth of the flywheel to turn it. Then push the TC back into the trans to lower it.
Hope this helps.
Sep 26, 2009 | 1981 Ford F 100
Traxxas Flywheel Nut- TRA5244 Logo
35 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
