Question about Sony Televison & Video
Tv is on an the picture blinks back and forth to black
    Top Expert:
  • Sony Master
  • 75,599 Answers
Hello
This is due to over voltage. Not related to supply in overvoltage, but the overvoltage that goes to the main board to this TV. Most TVs works oan a range of 85 to 120VDC. This voltage is generated from the internal power regulator. If the power regulator have any fault, the supplied voltage to the main board may either high or low. In both cases, the main system control IC on board, will detect it and will give you this symptoms.
The work is a skilled one, and only an expereinces service technician can make it right.
Posted on Feb 08, 2012
4 Suggested Answers
  • 81 Answers
SOURCE: sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Posted on Aug 19, 2007
Raditronic
  • 196 Answers
SOURCE: 27" panasonic tv, picture blinks and goes black frecuently.
cold solder in vertical ic
Posted on Apr 24, 2010
  • 252 Answers
SOURCE: pop sound tv went black,
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Posted on Aug 13, 2010
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Hello, Ive bought a new Sony Bravia KDL37EX402 television a while back and hooked it up to my computer via hdmi. When i turn on the television it blinks after 3 to 5 minutes from black, back to the...
Sounds like something must be loose. Try seeing how secure the hdmi port is on both ends first, unplugging them and then firmly plugging them back in. Then if the problem still persists, try unplugging the T.V. for a solid minute and then plugging it back in. If it still occurs, something might be loose on the inside, and you'll probably need some outside repair work done. If you purchased a warranty then you should be covered. You should also be covered if you didn't but the T.V. is less than a year old.
Jun 07, 2011 | Televison & Video
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
Nikon d1(I know its an oldie) screen is CRAZY!
Yes, the blinking is normal. read here for more info on what the display screen is telling you, plus a bunch more on your new camera: Nikon D1
Mar 26, 2008 | Nikon D1H Set Digital Camera
Sony kv 32s42 32 tv
Aug 05, 2007 | Sony KV-32S42 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
