Zebronics FX 5500-8X 512MB DDR - Computers & Internet
Image flickring when i played gta san andreas?
hello jaymarque, hi, try reducing the resolution, if not you should upgrade your onboard RAM around to 1gigabyte ram, switch your processor to Dual core 2.0GHz and or upgrade/change your AGP to a ram up to 512mb
Nov 20, 2010 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
1gb ddr2 ram is read as 512mb after upgrade from DDR. Also no system sound or audio is heard all drivers are working - mani
ddr=ddr only not ddr2, u may damage ur board pemantly,in bios it shows 512mb or in xp?,it will be because of board incopmpatibilty but the peformance will be as 1gd ram.
Jul 12, 2009 | Computers & Internet
Quero upgrate de memoria da winfast k7s741mg qual
Esta placa es compatible con memoria Ram DDR 266/333/400 , y los modulos no pueden ser mas de 512Mb cada, en cuanto la placa no suprota doble densidad.
Aqui el manual en Ingles: Easy Installation Guide
May 06, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Can i run ati radeon HD3650 512mb on asus k8N motherboard
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Jan 27, 2009 | ATI RADEON X1650 Graphic Card
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
How to upgrade memory
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove this first to change the memory.
Hope this helps
Dec 27, 2007 | NEC Versa FX Notebook
Problem when running games
Sounds very much like the capacitors are gone. Have a close look at all the capacitors. I think you will find some that have bulged at the top, may or may not be leaking brown liquid. If they are, look at it as an opportunity to get a better board!
Aug 01, 2007 | Foxconn 661MX Motherboard (FOX661MXMB)
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
