Question about Garmin Nuvi 660 GPS Receiver
Garmin comes through
I had the same problem with the external speakers not working. I called Garmin customer service and, even though my unit was out of warranty, they replaced it. I just got the replacement today. Good company. I'm thinkin' they must be aware of the defect. I suggest others do the same.
  • 10,594 Answers
Congratulations, you got nice experience. I will recommend your suggestion to others.
Have nice time.
Posted on Oct 22, 2008
I have had my Garmin for four years. Recently it has started shutting off when I'm driving with the set plugged into the adapter outlet. If I press the power switch, it will reboot, but then after a...
Garmin is voluntarily recalling certain nuvi devices that contain a specific battery that was manufactured by a third-party supplier within a limited date code range.
Garmin has identified potential overheating issues with the use of these batteries in certain nuvi devices with a specific printed circuit board (PCB) design. Additional information about the nuvi battery PCB recall can be found in Service Alert Number: 1035.
The models that may be impacted by the nuvi battery PCB recall are the 200W, 250W, 260W, 7xx and 7xxT (where xx is a two-digit number). To determine if your unit is affected, please visit www.garmin.com/nuvibatterypcbrecall and enter your nuvi's serial number. If your unit has the specific PCB design and contains a battery from the specific date range, you will be given instructions on how to return your nuvi for a battery replacement at no charge.
You should not attempt to remove or service the battery on your own; all battery replacements must be serviced through Garmin's authorized service provider.
If you do not have web access, you may contact Garmin through one of the phone numbers below:
  • In the United States and Canada, call (866) 957-1981
  • In North America and South America outside the U.S. or Canada call (913) 397-8200
  • In Europe, Middle East, and Africa, call +44 870 850 1242 or 0808 238 0000
  • In Asia, call 886/2.2642.9199
  • In Australia, call 1800 113 738; and in New Zealand call 0800 427 652
Repair time will vary based upon location. U.S. customers, please allow 10-16 business days to receive your repaired or replacement device. Canadian customers, due to increased shipping and customs clearance times, please allow 20-30 business days to receive your repaired or replacement device.
Garmin sincerely regrets the inconvenience that this recall has caused and is making every effort to cooperate with customers, dealers, and regulatory agencies worldwide to ensure all parties are assisted according to national regulatory standards
May 24, 2011 | Garmin Nuvi 660 GPS Receiver
I just received my neww 1450LM Garmin Nuvi GPS today and it push the on/off power switch and it does not come on. so, I started my car and plugged it in and it still does not come on. Please tell me why it...
May 24, 2011 | Garmin Nuvi 1450LMT
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
Att 959 corded phone
Called AT&T customer service... they seemed to recognize the proglem... agreed to send a new unit upon receipt of defiecive unit, even if it is out of warrently... not a bad deal if they come though on the agreement...
Apr 29, 2008 | AT&T 959 Corded Phone (att00386)
Missing the letter S
I called Garmin customer service and they told me to plug the unit into my computer and it would reset itself and all the letters would be restored. I did this and it worked! I realize the usb cable does not come with the Garmin nuvi 250, however you may have a cable that came with a cell phone or a digital camera. My camera cable worked great.
Feb 03, 2008 | Garmin Quest GPS Receiver
Garmin Nuvi always behind
Is WAAS enabled? If not then turn it on. This will give you better accuracy. You could also try using an external antenna if something inside the car or the windshield is causing interference with the GPS signal.
How fast are you traveling when approaching the turn?
Jan 25, 2008 | Garmin Nuvi 660 GPS Receiver
Failure to acquire satellite
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS GARMIN 340 turn it off by itself.
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
