Question about Baumatic Ovens
Baumatic baf9006 digital clock won't reset
The digital clock on my Baumatic oven constantly flashes and the instructions for resetting the clock do not work.
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
SOURCE: Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Posted on Jul 27, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
barkencoa
  • 3463 Answers
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Posted on Feb 21, 2010
SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Posted on Apr 02, 2010
After a power cut my Baumatic oven won't now work. Power is going to it, time is correctly set but oven won't turn on. Any help appreciated.
If this unit is still under warranty, Baumatic will repair it for free. Their service number is 0118 933 6911. I recommend trying them first before making any repair attempts. You could try unplugging it for a couple minutes to reset the computer.
Jun 13, 2016 | Baumatic Ovens
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
Why is error code F8E0 appearing on my Baumatic B205SS oven and alarm sounding
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
Mar 03, 2010 | Baumatic B205SS Stainless Steel Electric...
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Oct 11, 2009 | Baumatic B187 Stainless Steel Electric...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
105 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
