Question about Garmin nuvi 1350 Car GPS Receiver
How to sort favorites by name in garmin nuvi 1350
SOURCE: Transfer "favorites" from Garmin Nuvi 660 to 765T
I had the same problem. I called Garmin and the lady said if I had the software Map Source or something, that can do the trick, but the funny thing is you have to buy the software with Map Updates, or you get the software when you buy a new unit, and register the unit within 60 days of first satellite reception. Though I searched internet and someone said to copy a certain file/folder or I'd rather just copy the whole GPS folders and that might do the trick. You are right, this is a pain in the rear end.
Posted on Jan 13, 2010
IrishDruid
  • 2712 Answers
SOURCE: Garmin Nuvi 260 - Favorites won't open
You could try a master reset:
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. After the unit powers ON, you will see a new message: Do you really want to erase all user data?
  5. When this message displays, remove your finger from the bottom right of the screen and touch Yes.
  6. The unit will go through the Master Reset.
  7. Follow the onscreen instructions to set up your nuvi.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 26, 2008
  • 4090 Answers
SOURCE: my garmin nuvi 1350 powers down while travelling i
ALL GPS require charging via the AC charger or USB supplied, If you have not done this then the battery will lose power quickly when connected to 12v car outlet. This source is a maintenance charge, not the main charger. Therefore it will deplete and try to shut down, despite being connected. Holding the power button on to force it is a dangerous driving practice and will eventually damage the unit( not so bad as getting you and any passengers damaged by this practice)
Charge your unit fully before you use it, if that is daily then disconnect it and put it on the AC or USB to raise the charging level to full so it's ready to go for the next day.
If it fails to charge fully, then your actions have damaged the battery and it will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 21, 2009
Testimonial: "thanks for that very helpfull"
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
SOURCE: garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Posted on May 10, 2010
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1350 Car GPS Receiver Logo
302 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
