Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Setting up netflix on a sony Grand wega - Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
SUPERMAN_B_1
  • 294 Answers
SOURCE: Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Posted on Mar 18, 2009
SOURCE: Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
Posted on Sep 02, 2009
ladywinn
  • 5138 Answers
SOURCE: Sony grand WEGA 60" with tiny blue dots all over
Sorry but you have a BAD light engine Sony is well know for this part to go bad quick, I think your tv is DLP?
Posted on Sep 18, 2009
  • 1525 Answers
SOURCE: how can you test if sony grand wega lamp is faulty
hello if the lamp is faulty the bottom light will flash on the front of tv. the other way is to take the front cover off and check the lamp by eye. the wire inside the lamp will be burn't good luck
shaun
Posted on Oct 24, 2009
Testimonial: "hi thanks for your help i wiil try this."
  • 1525 Answers
SOURCE: reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Posted on Nov 06, 2009
How can I hook up headphones on my Sony Grand Wega 60" TV?
There are wireless units on the internet that can be connected to most sets--do some research with Google.
Dec 09, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Is there another way to access my Sony Grand Wega 50
I would have the remote itself checked--every TV shop has a tester for this----rule it out first.
Either it is bad (shops do fix them) or the remote receiver in the set is at fault----reason to find out if the remote is good or not first.
Aug 30, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Multiple blue spots on the sony Grand WEGA KDF-60655 60in TV
Indicates for model shown a bad optical light engine---check with Sony as several models this is covered even if the set is out of warranty (CLASS ACTION LAWSUITS GOT THIS).
It is the most expensive part in the set not even of course counting labor to replace it.
Mar 18, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
How do I reset the Lamp Timer on a Sony Wega KF-50WE620 TV?
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Jun 29, 2011 | Sony Grand WEGA KF-50WE620 Television
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
What are the best video settings for the Sony grand wega sxrd Kds-R60xbr1
Video quality, use component hook ups.
Sound quality, get a reciever/home theater system.
Oct 31, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No audio hdmi
Make sure you have gone into the Audio Settings and changed it to receive HDMI Audio.
May 06, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
