Question about HP Digital Sender 9100C Path-Through Scanner
My 9100c digital scanner is not compatible with windows 7 home premium how can I make it work
  • Alexandra Angel Feb 08, 2012
    9100C digital sender HP
3 Suggested Answers
  • 5 Answers
SOURCE: Make it work with VISTA home premium
What version of Windows are you using it on at present, or have you been in the
past? If XP then get the latest versions from:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?
os=228&lc=en&cc=us&lang=en&product=59968&dlc=en
There's a main download and an update.
If you have any HP software that you have tried uninstall it using Remove
Programs and then disconnect the USB cable from the PC end and install the XP
software as follows:
Locate the downloaded file ps804en.exe 1/1 (70.62M) on your computer, Right
Mouse Click on it and select Properties / Compatibility TAB.
On that TAB, check Use Compatibility mode and set it to XP with SP2 and also
check lower down the [x] Run as Administrator and OK your way out.
Do not connect the device until the installation procedure tells you to or
until you get to Finish.
Then repeat the procedure on the downloaded update file ps803mu.exe 1/1
(373.11k) although you can leave the USB cable connected unless it tells you
otherwise.
Posted on May 18, 2010
  • 111 Answers
SOURCE: Is Vista Home Premium Computer 32 Bit compatible
Your Hp scanjet 5300c scanner is not compatible with win 7 hoe premium 32-bit.hp does not have software or driver downloads available in that operating system.
Posted on Jul 27, 2011
Testimonial: "That's what I was afraid of. Thanks for verifying."
CanoScan 8000F Installation for Windows 8.1
Unfortunately, the Canon 8000F is not compatible with Windows 8.1. You can find this at http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductViewerWithDefaultFilters?TempOsid=Windows%208.1&Locale=en-us&Architecture=X64&TextSearch=CanoScan%2B8000F&Type=Both&CurrentPage=0&TotalPages=1&ShowCriteria=0&SortCriteria=Relevance&Compatibility=Unknown&LastRequested=14. Canon choose not to write a Windows 8 or 8.1 driver for this scanner. The changes between Windows 7 and 8 mean that the old driver won't work. The compatibility mode doesn't help in this case.
You have two choices: The cheapest option (if you buy a used machine): You can get a second computer with Windows 7 or an older version of Windows installed that does support the Canon 8000F. Alternatively, with a computer with more than 4GB of memory and a CPU that supports can support a virtual OS to buy 1) an upgrade to Windows 8.1 Pro and 2) a Windows 7 license and DVD. (This will cost at around $200 for Windows 7 Home Premium and the upgrade.) Then you can add the Hyper V feature and install Windows 7 as a virtual OS with at least 2 GB of your memory assigned to virtual OS. Install the scanner in that virtual computer.
I hope this helps.
Mar 06, 2014 | Canon CanoScan 8000F Flatbed Scanner
Tip
Sony Memory Card File Rescue Service If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
use Sony's Memory Card File Rescue software to recover your data.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Download Sony Memory Card File Rescue Here.
I hope that helps.
____________________________
Download Sony Memory Stick Formatter here.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
Is the Canoscan lide 35 compatible with windows 7 Home premium. I tried a lot of so called solutions, but non of them works. Thks
This scanner was not supported in Windows 7, however, you may be able to run it in compatibility mode, this link here may help
Jul 27, 2011 | Canon CanoScan LiDE 35 Flatbed Scanner
Tip
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Is Vista Home Premium Computer 32 Bit compatible with an HP 5300C scanner?
Jul 27, 2011 | HP ScanJet 5300C Flatbed Scanner
I have been given a medion scanner August 2002 and hoped to scan some old photos by using my new laptop DELL WIDOWS 7 HOME PREMIUM.no such luck.My laptop will not recognise or connect to it.I have followed...
Hi alistair49,
Firstly, is your laptop connected to the internet when trying to install your scanner?
Windows 7 will automatically browse Microsoft's online database of drivers if it's not found in your laptop database.
If you are in fact having driver issues, have you checked the following web page to locate your scanner software?
http://www.medion.com/gb/service/download/driver.php
If, however, you have the drivers, make sure that these are compatible with Windows 7 as your scanner was manufactured before Windows 7 existed. In this case try using Windows 7 compatibility wizard to install your scanner software.
You can do this by right-clicking on the installation file & selecting "troubleshoot compatibility" from the drop-down menu. Simply follow the on-screen directions step by step to check if Windows 7 has compatibility issues with your scanner software. In most cases this procedure should solve your problem.
Best wishes,
Graeme.
Mar 23, 2011 | Computers & Internet
I contacted help via the chat option...they had me reinstall the software/drivers, and my scanner still doesn't work. I can print but can't scan. I'm using WIndows 7 Home Premium edition on a brand new...
If you installed a windows 7 compatible driver it should work. If the driver you installed is not compatible try running the "troubleshoot compatibility" by by right clicking on the scannner program icon then click on troubleshoot compatibility.
Oct 04, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Digital Sender 9100C Path-Through Scanner Logo
63 people viewed this question
Seeker5211
Seeker5211
