Question about Kenmore Elite 45986 Front Load Washer
Timer kenmore elite 110.20952992
Machine starts the wash but timer does not move I have to manually move dail to spin then rinse ect.
  • 63 Answers
Its needs the timer if it doesnt have the small white piggy back timer motor
Posted on Nov 14, 2008
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Will not spin
You have either a bad lid switch, a bad drive coupling or a bad timer. If you can move the timer dial to spin manually and turn it on and it spins the lid switch is good and the timer is bad. If you manually move it to spin and the motor runs with no spin, the drive coupling is bad. If you manually move it to spin and nothing happens, the lid switch is bad.
Jun 11, 2009 | Kenmore Washing Machines
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Kenmore Elite top load washer timer will not rotate by itself through the wash/rinse/spin cycles
Gkar06,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Each portion of the wash/rinse/spin cycle work correctly, but you have to manually move the timer to each cycle.
This tells us the timer is bad and needs service to replace it!
You will be fine, it is not a big job!
If you like you can try this first!
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know!
Please remember to enter a rating before you leave.
Thank You
Sep 25, 2008 | Kenmore 24032\24036 Top Load Washer
Clothes washing machine
Fist off the unit is operating ok it was designed to only spin after the water is let out. by you opening the lid and closing it you have paused the machine (opening the lid) and started it back up This function is also built in the timer to pause the machine then go into spin.. The timer sounds like it has a dead spot in it. is this the only place in the cycle it does this ???? or does it stick and not advance say in the Agitate portion of the cycle?? there is a small timer motor on the timer that advances it it could be going out l. If you check that out with no luck the part # for the timer is 3954449 is is about $102.00 at www.sears.com it is $109.00 at www.apdepot.com the little drive motor on the timer is not a replaceable part the whole timer will have to be replaced
Hope this Fixes Ya
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
