Question about Xerox WorkCentre XD155DF Laser Printer
Xerox XD 155DF producing a loud sound of a gear turning against a fixed object. Sound seems to be coming from upper back right corner of unit; and seems to be related to paper transport - because t
Loud "Gear turning against fixed object" sound when copy button is pushed. Coming from top right rear of machine. Paper will not fully transport through unit. Stops by drum unit.
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
SOURCE: ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
Posted on Jul 24, 2008
marked
  • 6487 Answers
SOURCE: Xerox Work Centre XD 125f/E2 red misfeed indicator/status code
You're very much welcome, dont forget to rate my solution FIXYA from your original port , feel free to contact us back...
Posted on Aug 20, 2008
  • 2072 Answers
SOURCE: Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Posted on Aug 31, 2008
  • 2072 Answers
SOURCE: Xerox 412
This post is loaded. First of all, there should be 4 screws holding in the fuser. Unless you are talking about removing the 2 screws that hold the pressure and heat roller together in the fuser. 4 screws hold the fuser in the machine, 2 screws hold the fuser together. I am not sure exactly if your fuser was mounted to the machine with only 2 screws, or if that is an accurate post and you removed the 2 screws that hold the fuser frame together. Either way, I seriously doubt the noise is coming from the fuser itself.
Now, the darker section down the middle. I would suggest taking the fuser back out of the machine and looking at the black heat roller in the fuser. If it is not clean and shiney, and has a rough texture to it in the middle, that roller is bad and will require replacing the fuser.
What I am curious about is, the rest of the copy. Is the copy fine outside of the middle? If so then the fuser should fix it. Note if there is some reprint, sort of ghost print in the middle of the page.
The rattle may be the gear on the back of the drum cartridge, It is a small gear that drives the cleaning roller. Pull out the drum and look on the back, there are 2 small gears on the back . One of them may have broken a tooth and is jumping and not rotating properly.
Another problem, as I read this may be the toner cartridge not having the ink distributed properly, To eliminate the toner cartridge as the problem. Remove the toner and look at the roller on the front of the cartridge.It shoud have ink distributed evenly across that roller, No streaking, it should be a dull black fuzzy apperance across the roller.
Firstr check the middle of the fuser roller for the wear I described. Then the back of the drum for the noise, then the toner carteidge for distribution.
If its not fixed yet, let me know. We can discuss the laser and scanner issues. But those are far less likely.
You posted a good one...
Posted on Sep 24, 2008
What is the cause and solution of a grinding noise when printing from a xerox workcentre 6605dn color laser
Defiantly a main drive issue, slipping belt can make the noise you described, sometimes the pulley gets tight or the tensioner binds causing the belt to slip
May 17, 2014 | Xerox WorkCentre 6605/DN Color Laser...
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
My xerox machine is making really loud funny noise that are unusual, it makes the noise while it is warming up and until it prints, it is out of the ordernary sounds that we hear from it. it is more of a...
could be a few things... take out the drum and make sure the toner is put back in. then keep the right side door open and push the silver metal flap down near the back of the door opening (its the interlock that tells the machine the right side door is closed) and see if the noise occurs. if it does then you no its not the drum. so u can reinstall it. try to pin point the source of the sound with the right side door open. could be one of the many gears in back or the fuser (which is above the green colored drum) 4 screws and one wire harness takes off the fuser and u can physically inspect to see if the gears are missing any teeth or the bushings are broken. if all looks well then reinstall turn machine around and take off the back cover (6 screws) wiggle it off and turn the machine on and look closely at all the gears on the left(looking at the back) top side. when it starts it warm up process check to see if any gears are making the sound or cracked. if those gears are shot u mught need a new main drive assembly which is really difficult and time consuming to repair.
Jan 17, 2011 | Xerox WorkCenter 4150 Black and White...
Hello everyone I have a sharp AL-1631 copier and when it starts there is a loud clacking sound coming from the rear drive side of unit can anyone aide me in a resolve?
There could be a few things wrong, but you most likely have a worn out fuser rachet gear, that drives the fusing unit or you may have a worn or broken fuser gear on the upper fixing roller. You can order the parts on line for about $20.00 + shipping. The only hard part is replacing the gears... The one on the Upper fixinfg roller is not that hard, but the rachet gear is kind of tricky... Alot has to come apart and then back togather. It is not hard, but you have to remember where the parts go back too. If you are not very comfortable with taking this apart, it may be a little to much to handel... It, could be just as simple as tighting the fuser screws??? Good Luck..
Apr 18, 2009 | Sharp AL 1631 Copier
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Jenn-air refrigerator model #jcb2389grs
You need to replce the adaptive defrost control that is located in the refgerator section of the unit . it is the upper right hand corner of the contols you must disasemble to find it . you must also defrost your freezer
Aug 17, 2008 | Kitchen Ranges
Constant whirring noise and won't print
I do have the same problem with my psc-2175. I opened it and recognized that the problem is with the scanner unit. There is a sonsor in this unit which locates the scanner lamp at the beginning point when you turn it on. When this sensor fail to function, the electric motor, which moves the scanner lamp will not recognize where to stop and it works without any stop. So it pulls lamp unit into its borders and make the noise you hear.
I wanted to let it repaired, but I found out that it will be very expensive and it is better to buy a new set. I have bought it in Iran 1600000Rls (170$), and the repair cost is almost 750000Rls (78$).
If you find another solution please let me know, my email is: decoder84@yahoo.com and my name is Soroush Asarzadeh.
May 08, 2008 | HP PSC 2175 All-In-One InkJet Printer
Paper in copier hangs up
it sounds like the heat roller gear has broken. open machine and look @ the heat section in the back you should see the gear broke.
Nov 04, 2007 | Xerox WorkCentre XD120f Copier
Xerox WorkCentre XD155DF Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
