Xerox 8830 and a 7356. Scanner has a clock constantly and doesn't illuminate
  • 1,294 Answers
Verify the scanner drive sistems,motor or the scanner home sensor .
Posted on Feb 08, 2012
2 Suggested Answers
SOURCE: I'm setting up a 8830 and a 7356. The scanner
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Posted on Dec 23, 2009
I don't have the install disc for Xerox One Touch 2400 Flatbed Scanner - can you help . thank you .
I've located the drivers for your scanner at the UK Xerox Website:
http://www.xeroxscanners.com/en/uk/products/X2400/drivers.asp
As for the bundled software, it seems that it is unavailable. You could try to order it from Xerox. I would start by calling this number:
http://www.xeroxscanners.com/en/us/WhereToBuy.asp
Good luck
Sep 23, 2011 | Xerox One Touch 2400 Flatbed Scanner
I can't turn off either alarm on the timex T308S and it's driving me crazy. I downloaded he lame manual. It's all about how to turn on the alarms. The little amount of information I found on...
  • Hi, I can help.
  • As long as the alarm indicator is illuminated on the LCD screen the alarms will sound.
  • To get rid of the alarm indicator press the "enter" button on the top of your alarm clock. No more alarms at all.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for leaving FixYa.
Regards, Tony
Aug 24, 2011 | Timex (T307S) Clock Radio
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
I had lost the driver CD of Xerox workcentre 3119,after down load the driver and scanner from Xerox website,the printing was back to normal,but can't scanning due to scanner icon doesn't appear at...
erm your best bet is to find where you installed the scan software and find the icon there. Once you fond it create a shortcut to that icon on the desktop.
May 10, 2011 | Xerox Office Equipment & Supplies
Can you help me . . ? ?
u cannot convert black and white scanner to color
Apr 30, 2010 | Xerox 8825 Copier
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Wiring for the radio wires
most head units are: black=ground red=battery + switched orange=illumination yellow= battery constant + (for clock) blue=remote turn on for amps/eq/power ant...etc. then the green pair, purple pair, grey pair, and white pair are the speaker outputs. I am not sure if this is the color scheme Jensen uses, but I think it's mostly universal.
Jun 13, 2009 | Jensen Car Audio & Video
I want to wire the kd-s640 to my boat. I need to know what wire by color (except black ground) goes where. Thanks. dave.dunklee@gmail.com
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Jun 12, 2009 | JVC KD-S640 CD Player
Need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
Apr 25, 2009 | Car Audio & Video
128 people viewed this question
jasbo
jasbo
