Question about Sewing Machines
Machine is skipping stitches
Viking 990 S. Machine had been working fine. Halfway through project, it started skipping several stitches at a time, only occasionally catching the bottom thread.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
One of the things that can cause this is lint buildup around the back of the hook driver. Open the bobbin cover and look just above the hinge, at the bottom edge of the black hook cover. If lint is peeking out at you, it may be time to have it serviced. You may be able to get most of the lint out if you remove the needle plate and blow onto the back side of the hook area with canned air. Keep the cover open so the lint can come out.
Now I am assuming that you have replaced the needle.
Posted on Oct 23, 2008
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
10 reasons for skipped stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Skipping stitches?
skipped stitches is usually an indication of timing of hook and needle being off. The needle is not always picking up the bobbin thread. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck. Home
Feb 18, 2015 | Husqvarna Husky 165
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
Apr 14, 2011 | Husqvarna Viking 1
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
I own a husqvarna classica 100 the problem I am having is it is skipping stitches. It is used solely as straight stitch machine.
Have you changed your needle? Try that first, if it doesn't work, the timing is off and needs repair.
May 09, 2010 | Husqvarna Viking 1
Thread breaks and skips stitches
Open the needle plate, remove the bobbin and bobbin case.....refer to your manual.
Clean away lint and threads.
Thread with the presser foot up.
If this continues, take the machine and samples of the mis-stitching in for service. It could be the timing needs to be adjusted by a professional.
Feb 20, 2010 | Husqvarna Viking 1
Machine sews, but skips stitches. i've tried tightening the tension, but it didn't work
Good luck.
Feb 11, 2010 | Husqvarna Viking 1
Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Jun 15, 2009 | Husqvarna Viking 1
Sewing Machines Logo
146 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
