sal am un siemens fujitsu amilo si am nevoie de draiverele audio video mentionez ca am cautat pe net dar nu gasesc ma puteti ajuta cer scuze de scris dar sant la anceput multumesc
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS...
(More)
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS settings wrong CMOS date/time incorrect Press F2 to run setup No keys work so pressing F2 does nothing. The laptop worked fine 2 days ago. I have renewed the internal battery but still get the same message. I cannot move pass this error screen Can you help? Thanks, BR Peter
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non...
(More)
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non disabilitano le casse interne
My new Fuj-Siemens Amilo laptop has a different cable socket to the earlier standard external...
(More)
My new Fuj-Siemens Amilo laptop has a different cable socket to the earlier standard external monitor and projector cable sockets! Is there a converter or special cable available and from where. What is its official description. I want to connect to a standard projector. The socket on the rear of the Amilo has a logo of an oval with an arrow and square bend sign!! Your advice would be appreciated.
thanks -i will try the information you gave me-the screen also stays black-but when i remove the...
(More)
thanks -i will try the information you gave me-the screen also stays black-but when i remove the graphics card it lights up to a white screen-could this be the battery or graphics card??
