Question about Casio FX-9860G Graphic Calculator
Can you calculate indefinite integrals on the casio fx-9860G
  • Casio Master
  • 7,993 Answers
Unfortunately, the Casio FX-9860 G does not have a Computer Algebra System or CAS. For this reason it can only calculate definte integral over a given interval. The lower and upper limits must be supplied. The result will be a number.
Casio calculators that have a CAS are the Casio ClassPad CP330/ 300Plus/ 330, or the Algebra FX 2.0.
Posted on Feb 08, 2012
  • 7993 Answers
SOURCE: how do you find out
The following screen captures are from another Casio Graphing calculator so the menu screen may not look yours. However the instructions are identical.
Here is a sequence of screen captures to illustrate how to do it.
Turn calculator ON. Use arrow to highlight STAT and press EXE
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
If you choose Cpd : you must enter the Chi value you want, and press EXE, then the number of degrees of freedom (df) and press EXE. The Execute command is highlighted. This allows you to perform the actions
indicated by the Thumbnails at the bottom of the screen: calculate a value or Draw the distribution.
In the example above I took Chi=1, and df=3 and pressed the CALC menu.
If I press the DRAW menu instead, the distribution is displayed.
If you want the other distribution Ccd, press Ccd instead in screen capture 4.
Posted on Aug 04, 2010
  • 7993 Answers
SOURCE: Casio fx-9860g ............ how to do percent operation
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
Posted on Oct 01, 2009
  • 7993 Answers
SOURCE: Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
Posted on Jul 25, 2010
  • 102366 Answers
SOURCE: Is there a way to
No. The calculator can compute definite integrals by numerical integration, but it does cannot do indefinite integrals.
Posted on Feb 11, 2011
  • 7993 Answers
SOURCE: prime factorization using Casio FX-9860G Graphic
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Posted on Aug 01, 2011
HOW to solve integration on casio fx-991es
The fx-991ES does not do indefinite integrals.
For definite integrals, use the [integral] key just below and left of the big round cursor pad. For example, to calculate the definite integral of x^2 dx from 0 to 1, press [integral] [alpha] [X] [cursor-right] [0] [cursor-right] [1] [=]. After about a second you should see 1/3.
Dec 20, 2014 | Casio Office Equipment & Supplies
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
Aug 30, 2014 | Office Equipment & Supplies
Casio FX - 9860G SD have complex equations??
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
I have the casio fx 9860G. how do i take a screen shot form the calculator and then get it on a word document?
The easiest way to do this is to take a photograph with a digital camera or mobile phone and transfer using blue-tooth or data cable to a PC.
Mar 24, 2011 | Casio FX-9860G Graphic Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
Is there a way to calculate indefinite integrals (anti-derivatives) with the Casio FX-115ES?
Feb 11, 2011 | Casio FX-115ES Scientific Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
Installed a wrong OS update version
get battery out-and install it again(after you return the battery)
Jun 27, 2008 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
2,497 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
