Question about LG LRE30451ST Electric Kitchen Range
H5 keeps coming up on my lg oven
After i try turning off the burners, occasionally "h5" is displayed and will not disappear from the surface control
2 Suggested Answers
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE Profile range - Digital display went blank when the surface burner was turned on
Hi
Mercedes NEC device can learn an extra key to ALL MB MOTOROLLA AND HAVANA AMAZONAS PALERMO... EIS with black or chrome key Version57
Device can repair any CORRUPTED key data VIA INFRA RED
Device can repair the old 204 steering lock or program a new steering even if the old ESL in not exist
Device works by infra red Much and much functions will be valid to all our customers
Price 7000 Euro you can visit our website to watch the you tube video
(Limited quantity only)
http://youtu.be/0Ce4z8JY-go
•Mercedes W204 - ELV
•Mercedes C W204
•Mercedes CL W216
•Mercedes A W168
•Mercedes G W463
•Mercedes GL W254
•Mercedes GLK X 204 - ELV
•Mercedes GLK X 204
•Mercedes ML W164
•Mercedes W 207 - ELV
•Mercedes W 212 - ELV
•Mercedes W207
•Mercedes W212
•Mercedes G W463 (MOPF)
•Mercedes W221
•Mercedes SL R230
•Mercedes SLK R171
•Mercedes Sprinter
•Mercedes Vaneo W414
•Mercedes Viano W639
•Mercedes R W251
•Mercedes Vito W639
Dec 28, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Surface ignitors dont work
The oven and burners have separate igniters. There may be a battery that needs to be replaced for the burner's igniter module.
Feb 16, 2012 | Amana ACS3350 Gas Kitchen Range
My right front burner wont turn off. My dad checked the control knob and it seems to be working. He unplugged it from the front burner and put it on the back to see if it did the same thing and it did. ...
with a model number to know exactly how power is supplied to the surface burners its going to be hard to let ya know anything definate...but do ya have knobs that ya turn to turn on the surface burners? if yes knobs..their will be terminals on the switch marked L1/L2 on those 240vac should be there all the time when turning the knob onto high on terminals marked H1&H2 should be 240vac to the burner
if it has the touch button to turn on the surface burners 240 vac into board all the time ..4 individual outbound power places (one for each burner) and the one for that burner also should have 240 vac when set to high
in either case if 240 vac out to burner the burner is bad
if 240vac into switch/board and not out..switch/board bad
Aug 26, 2011 | Kenmore 99123 Electric Kitchen Range
The "hot surface" light will
for the burner problem if the hot light wont go out you have a bad burner, that burner has a limiter on it that tells you when the burner is hot. as for the oven light i would try to change the bulb
May 12, 2011 | Kenmore Microwave Ovens
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Mar 24, 2011 | GE Profile JGP636 Gas Cooktop
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
My oven takes a long time to light and there is a strong smell of gas..why?
This can be caused by a weak/inop hot surface igniter ,defective gas control valve or debris in the burner orfice/venturri. The gas odor is going to be caused by unburned gas due to a by-passing gas control valve or a weak igniter(not lighting the gas coming from burner) First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the by-passing problem. If the oven burner comes on when tapping the valve then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. Also inspect the burner venturii and burner orfice for any possible debris(grease,lint ect) that could be restricting gas flow. One more thing you can try is to manually light the burner. Make sure the oven and burner compartment are COMPLETELY cleared out of gas. Then make sure there is a flame from a match or lighter right next to the burner where the igniter is located(it is best to use a long fireplace match) before starting oven. Once the flame is lit and next to the burner then turn on the oven thermostat and listen for the flow of gas. Once the flow has started the oven burner should light immediately! If the burner does not light within 2 seconds the remove the flame and shut down the oven. If the burner lights with the match then either the igniter is not hot enough to light the burner or there might be a restriction in the burner head blocking the flow of gas to the hot surface igniter...or a restriction in the venturri or orfice. You will need to be extremely careful performing these procedures! If you are smelling gas then the oven and burner compartment could fill up with enough gas to cause a delayed ignition! You could get burned or seriously injured so I advise you not to try these procedures if you are not experienced with gas appliances. You are taking your own risk trying these procedures and if you feel uncomfortable trying these then I suggest call a professional.
Apr 17, 2010 | Tappan TGF363 Gas Kitchen Range
LG LRE30451ST Electric Kitchen Range Logo
270 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
