Zebra Printer zm400
Hi all, I have a problem with the company's Zebra printer. We have 3 Zebra printers in the warehouse. 2 internal wired and 1 external wired. The [roblem is the 1 zebra internal wired printer has been accidentally resetted by the warehouse guy. and now i don't know the exact IP address of the said printer. is there any way that i can trace what is the IP of the said printer? like a history or something? i'm just new to this zebra printers and i am the new IT guy in the company. even i traced it with the IT guy before me, he said he didn't have a copy of the network settings also.. please any help would be appreciated. thank you all
  • 1 more comment
  • deep tracy Feb 21, 2012
    Hi Mohammed, thanks for your reply. We still have this problem until now but i found out that it can print now using the Internet Explorer. But in SAP, we can't print. Is it possible that it is the printer and network settings inside the SAP? We can't edit or access the settings of this printer in SAP. Is there a way on how to edit or show the settings in SAP? or should we contact the SAP Europe Team who set up this? thanks sir
  • Mohammed Rizwan
    Mohammed Rizwan Feb 21, 2012
    In SAP is believe the printer is configured on this path
    SPAD--->Configration---->Output Devices---->change---->create---->user defined Output device and Short name
    You may check the setting there.
    SAP printing guide:http://help.sap.com/saphelp_nw2004s/help...
  • deep tracy Feb 23, 2012
    Hi sir, Thanks for the reply . i will try and take a look at the link you had shared. Appreciate so much your effort. Take Care
    Guru:
  • 731 Answers
You may try anyone of these option.
  • If you had this printer registered in the DNS, then its possible to obtain the IP assigned to this printer from the DNS server.
  • Earlier was the printer mapped to any print server on the network? if yes, you may obtain its IP from the print server.
  • Check the DNS cache from any PC that used to access this printer. Command to display DNS case is "ipconfig /displaydns"
Posted on Feb 08, 2012
ashish13
  • 75 Answers
SOURCE: Some noise comes when printing
Here is the link for the Service Manual required which i uploaded for you... hope this resolves your issue...
http://www.adrive.com/home/downloadfile/136030403
Posted on Feb 12, 2009
  • 257 Answers
SOURCE: how to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Posted on Jul 10, 2009
prashanthcl
  • 460 Answers
SOURCE: zebra printer Zm400 - error condition
pls clean your printer sensors.
Posted on Aug 21, 2009
  • 31 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
I agree with Dustproof's suggestion regarding setting defaults. After you do that, you will need to set up your firmware and driver for the correct density, speed, media handling (tear-off vs. peel - labels with gaps or black marks) , etc. If your driver does not relfect the same settings that you have saved in the printer's firmware, the driver will send commands to the printer that will change its settings. Lastly, you will need to calibrate the printer to the media that you are using. An easy way to do this on the ZM400 is to set the power on setting in the LCD menu to calibrate and the head close setting to feed, save these settings in memory and then reboot the printer. This way, you will only need to reboot your printer to calibrate when there is a problem or if you change media types. The feed setting on head close will make sure that your label advances to the the next gap or mark if you open the printhead.
If all ese fails, call Zebra tech support (800) 423 0422 and open up a support case. It is possible that the media sensor or media led is not working properly requiring that your printer be sent in for repair.
Posted on Jan 30, 2010
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
How to downgrade ZM400 printer firmware
If the firmware here is the one you have, contact their support direct and ask them for the older version. You won't find it anywhere else.
ZM400 Industrial Printer Support Downloads Zebra
Jul 26, 2017 | Zebra Office Equipment & Supplies
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
Zm400 just keeps on spitting out blank labels even after a hard restart
It's possible the labels are not loaded correctly and are missing the label sensor. Be sure the labels are loaded all the way to the left, if you are looking at the front of the printer.
Jun 16, 2011 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Hi how can i reset the printer zebra lp2844 back to factory settings?
1.turn off printer
2.press and hold feed button
3.press power button
now led id blinking 3 time
4.then release both button
and single press feed button
now it will com receipt .... successfull
Let me know this helpful
Jan 06, 2011 | Zebra LP 2844 Thermal Printer
How to reset zebra z4mplus dt printer setting
Factory Reset
Press Setup/Exit - 2 Times
Press '+' - 3 Times
Press 'Select' - 1 time
Jul 14, 2010 | Zebra Z4Mplus Label Printer
384 people viewed this question
k24674
jasbo
jasbo
