Question about Compaq Presario sr1055cl PC Desktop
Remove A: drive compaq presario sr1055cl
How to remove floppy drive
  • Compaq Master
  • 32,281 Answers
Remove the side panels on your desktop computer. The floppy drive will be attached to the drive bay with 4 screws (2 on each side of the floppy drive) or by a plastic slide clips. After removing the screws, remove the power cable and the data cable from the back of the floppy drive and then you can slide the floppy drive either to the back or the front of the drive bay to remove the floppy drive from the desktop case.
Posted on Feb 08, 2012
gunjansarkar
  • 55 Answers
SOURCE: compaq presario SR1055CL
ok mary this might be a virus issue we have to forrmat the HDD....compaq ships the copy of the operating system with the system in the D: drive so we need to restre it back t the factory settings...so go ahead and run a recovery .....restart the system and keep tapping F11(vista) F10(xp)......it will take u to the recovery manager and the n click on advanced option and select the option system recovery......and select next and then select recover without backing up and then click on nect and it will now format the HDD back to factory settings and your issue will be resolved
Posted on Mar 19, 2008
ericbrunswic
  • 88 Answers
SOURCE: floppy drive doesn't work.......not listed on My Computer
Floppy drives are very cheap and easy to replace, another option, you might consider if you have a USB slot is to purchase an external floppy drive.
External's cost a little bit more but they are portable and you don't have to open the computer to install them.
Posted on Jan 18, 2009
khawar2006
  • 63 Answers
SOURCE: cant install drivers on my compaq presario
Please try using different options.
Option 1:
My computer>right click>properties>hardware devices>check the appropriate device>right click and then click update and then select your driver location and install.
Option 2:
This involves installing driver directly through its provided setup file, if available, and following on screen instructions.
Option 3:
If all does not work, please go to the concerned site of HP online and download the respective updated software as there is a possibility that software has been corrupted.
Please let me know if all does not work, then I will look for other alternate options for your problem.
Kind Regards,
KK
Posted on Oct 30, 2009
  • 433 Answers
SOURCE: I have a COMPAQ, Presario SR1055CL Desktop, that will not bootup
Hi....If the computer will not start and you hear no fans or other electrical sounds chances are the power supply has failed. If you had an electrical storm that caused the blackout and did not have a surge protector power strip it could be much worse. Check the power supply first. You can google for help in testing that supply. Good Luck Hank
Posted on Jul 26, 2010
  • 214 Answers
SOURCE: I been trying to restart my Compaq Presario
I suggest try to troubleshoot the problem of the machine if its a hardware or software, try to follow this steps. Just go to this link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07173&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=404613
Hope I've helped you somehow.
AnEspera
Posted on Apr 30, 2011
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
Compaq Presario sr1055cl PC Desktop type of video card
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=404613#N203 try here if the on board graphics has gone which happens on older pc's just buy a pci graphics card insert it and it should install itself hope this helps.
Feb 11, 2012 | Compaq Presario sr1055cl PC Desktop
Screen is saying, Disk Boot Failure, Insert System disk And Press Enter
Sounds like hard drive is going bad or just lost boot sectors, you need to put in your windows disk and follow prompts, or go to another computer and search for program called spin rite
Aug 18, 2011 | Compaq Presario sr1055cl PC Desktop
I been trying to restart my Compaq Presario SR1055CL Desktop PC to factory default and i read to press f10 to do the restart function when loading the computer. But it never works, i tried f11 and it takes...
AnEspera
Apr 30, 2011 | Compaq Presario sr1055cl PC Desktop
Jul 25, 2010 | Compaq Presario sr1055cl PC Desktop
Compaq Service Utilities floppy Presario 2100
Access: http://www.compaq.com/support
and search for 'Presario 2100', then click on 'Device Drivers'.
Nov 07, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq presario 900 512 ram to 1 gb?
go here http://www.corsair.com/
and do a memory scan
Jul 07, 2009 | Compaq (291647-001) for Presario 900 /...
Disk drive didnt run
make the hd. master on the primary, and make your d drive master on the secondary.
Jun 16, 2009 | Compaq Presario sr1055cl PC Desktop
Keyboard stuck
Disconnect the power cord and remove the battery. Wait for 30 seconds. Next, put the battery back in the laptop and reconnect the power cord. Turn the laptop on.
Be sure to also run a virus scan\malware check and update all your drivers.
Jun 01, 2009 | HP Compaq Presario 1700, 1700AI, 1700AP,...
Compaq Presario sr1055cl  PC Desktop Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
