Russell Miller Posted on Feb 08, 2012
Hunter DSP Wheel Balancer ERROR CODE 1,5,and8
Rosa Roa
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 27, 2018
Rosa Roa
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3402
Points
I have a hunter dsp 9500 tire balancer displaying error 11
Where can I purchase a STICK for my dsp7700 Hunter wheel balancer
Direct from Hunter
Hunter® Wheel Balancers - Choose a Hunter® Balancer
Ad·https://www.hunter.com/wheel-balancers
Learn How You Can Get The Fastest, Most Efficient Balance Possible With A Hunter Balancer. Standard & Heavy-Duty Hunter Wheel Balancers. Browse Our Models Online. Free On-Site Demos. Quality Equipment. Dedicated Sales &...
Road Force® EliteThe Fastest Diagnostic Balancer. Quickly Diagnose Vibration Issues.
Things To ConsiderChoose The Right Wheel Balancer. Learn About Key Balancer Features.
Find A Local ConsultantConnect With Your Local Consultant Reach Out Now.
COMO SOLUSIONAR EL CODIGO DE ERROR 3 EN UNA BALANSEADORA HUNTER DSP 9000
ENGLISH ONLY PLEASE. We are a North American website.
This is an automotive wheel balancer, so moved to a better category. Contact the maker in the country where you live.
https://translate.google.ca/?sl=auto&tl=en&text=COMO%20SOLUSIONAR%20EL%20CODIGO%20DE%20ERROR%203%20EN%20UNA%20BALANSEADORA%20HUNTER%20DSP%209000%0AME%20MARACA%20ERROR%203&op=translate
HOW TO SOLVE ERROR CODE 3 ON A HUNTER DSP 9000 BALANCER
MAKES ME ERROR 3
2answers
What does error code 2 mean on my hunter dsp wheel balancer
Call hunter support and request error code sheet. Let them know you are a end user and your machine is out of warranty. They should email or fax it to you.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Steering gets really sensitive at highway speeds. Hit a bump then car likes to shake left and right.
Sound like out of balance tire or a separated tire or bearing but, the two most common causes are the ones. I suggest visit some tire shop and would like to have the tires inspected and balanced.
Some customers may comment on shaking/vibration in the steering wheel, floor or seat while driving at highway speeds (typically between 60-72 mph (96-115 km/h)) on smooth roads.
These specific vehicles may be sensitive to various rotating mass assemblies, especially if they are considered to be out-of-balance.
In order to correct this:
1. Visually inspect the tires and the wheels. Inspect for evidence of the following conditions and correct as necessary.
- Missing balance weights
- Bent rim flange
- Irregular tire wear
- Incomplete bead seating
- Tire irregularities
- Mud/ice build-up in wheel
- Stones in the tire tread
2. Set the tire pressure to 30 psi (205 kpa) COLD.
3. If the road test indicates a shake/vibration still exists, check the imbalance of each tire/wheel assembly on a known, calibrated, off-car dynamic balancer. If any assembly calls for more than 1/4 ounce on either rim flange, remove all balance weights and rebalance to as close to zero as possible.
Important: Some GM dealers may have a Hunter GSP9700 Road Force Balancer. This will simplify Step 5 by not requiring dial indicators. If a Hunter GSP9700 machine is available, it may also be used to measure the radial force of the tire/wheel assembly. A guideline here is 18 lbs or less.
4. While on the balancer, measure wheel runout. If radial or lateral runout exceeds .020 in (0.50 mm) for aluminum wheels (.030 in (0.76 mm) for steel wheels), replace the wheel.
5. After confirming wheel balance and wheel runout, if any changes were made, road test the vehicle again.
6. If the smooth road shake/vibration still exists:
Important: The completed worksheet must be attached to the hard copy of the repair order.
Record Radial Force Variation readings if you have access to Hunter GSP9700 Wheel Balance equipment. Use the worksheet shown in this bulletin to record the readings.
If one or more of the tires have RFV readings in excess of 18 lbs, match mount the tires to get below 18 lbs. Readings of 12 lbs. or less are preferable for critical customer concerns.
If the RFV can not be reduced to an acceptable level, replace the affected tire with one obtained locally.
The screened tire program is no longer in effect for Bridgestone/Firestone, Goodyear and Michelin. Low speed screened tires are available from Continental General only, and only for the Buick LeSabre.
Road test the vehicle to ensure the shake/vibration has been resolved.
7. Replace both lower control arms on vehicles built prior to the VIN breakpoints shown. The new lower control arms may provide an incremental improvement to the vehicle ride. Customers who have become "tuned in" to the shake condition may still feel some shake in the vehicle after the new lower control arms are installed.
Refer to Lower Control Arm Replacement, (refer to the Parts Information table below for SI document ID numbers).
Important: THE CONTROL ARMS SHOULD ONLY BE INSTALLED ON VEHICLES IF, AFTER THE TIRE AND WHEEL DIAGNOSIS AND REPAIRS HAVE BEEN PERFORMED, THE VIBRATION CONDITION STILL EXISTS.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
2answers
Owners manual for Hunter DSP 9000
y need the squematic circuits for dsp 9000 wheel balancer. Please urgent, and y ned the spart list
Oct 23, 2010 • Garden
Avh-p5900dvd when trying to play dvd or cd comes up with...error-02-9e can you please help.
Here is the Pioneer error code table:
First Second Error
Digit Digit Description
0 No major error
1 Antenna not connected
2 Shorted antenna cable
3 RF circuit failure - PLL not synchronized
4 Undefined/Reserved
5 NVM Error
6 Defective CAP or not connected
7 Unknown DSP SW version
0 No minor error
1 CDEC Communication Error
2 SSDEC Communication Error
3 SSDEC No Response (DSP core freeze)
4 No signal/100% BER
5 Not activated
6 Not authorized
Your error indicates an
SSDEC Communication Error.
You should try resetting the unit to clear this error.
k24674
ADMIN Andrew
ADMIN Andrew
