Question about Home
Triton Electric Shower Temperature too hot
I've had my electric shower for about 8 years and it has worked perfectly. Lately the temperature is far too hot to nearly scalding temperature. We have to turn it right down in order to have a comfortable heat but then the water pressure is far less. There are two dials on the unit. The first has two levels, which is 1 red bar and 2 red bars. The second dial is numbered 1 to 10 (1 being cold 10 being v, hot). We have always had the shower on 2 red bars at between 5-6 for a comfortably hot shower. It now is scalding hot on 2 red bars from 1-10. We now have to have it on 1 red bar at number 8-9 which is far too cool and less pressure. We cannot get a comfortable temperature that is not too hot, not too cold that we used to have it before.
We have had the bathroom redecorated recently and the builders should not have touched the shower but they did update the circuit board.
Any ideas?
  • Anonymous Mar 12, 2014
    replaced thermal switch electrics fine and water pressure filter clean two years old no scale
    Champion:
  • 242 Answers
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Posted on Oct 23, 2008
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Nov 11, 2009 | Home
Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Mar 22, 2009 | Home
Triton Silhouette LED temperature fluctuations
Yes this one for the pro's call the company this is not something a most repair plumbers like to do...we would call the company they should know whats going on. If I was on the job thats what I would have to do, and then I would have them ship the parts to me. How old is it?
Feb 01, 2009 | Rubinet 41RBHOBK H2O 1/2 Temperature...
Shower temperature too hot
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Dec 10, 2008 | Peerless Industries Peerless& Single...
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
1,025 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
