I'll slide the power key down and the "Phillips" logo will show up then it'll turn off. Plus my computer won't recognize the driver. It says "Device driver software was not successfully installed" It's the MTP USB Device that failed. I don't know what to do.
SOURCE: System File Error on Phillips GoGear Vibe
you should be able to put it into recovery mode by holding the volume up button while hooking it up to the computer after that you should be able to do a recovery on it using the software provided with the player
SOURCE: how do i fix the GoGear VIBE 4GB when it freezes
pay2besmart
If you go to this link it will show you how to reset your player. This should resolve your issue.
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&subrequest=1&mid=Link_FAQs&new_tmpl=1&view=aa12_view_full.html&desc=Philips+GoGear+MP3+video+player+SA1VBE16K+ViBE+16GB&session=20100405002949_166.188.96.229&list=aa12_list_partial.html&slg=AEN&refnr=0074047&refdisplay=PAV_GENERAL_NOTTURNON&dct=QAC&ctn=SA1VBE16K/17
Let me know if you have any more problems or questions
Issken
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
SOURCE: I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Testimonial: "Great! That worked. Thanks so much!"
SOURCE: what video format does gogear vibe use?
The video format had to be a .smv file for Phillips GoGear Vibe player.You'll need to jump through some hoops to transfer videos into a low-resolution SMV video format.
The best and most reliable video converter tool that I've ever used is a tool called Enolsoft Video Converter. It's able to convert all videos between various formats. Easy to use and professional. You can use it for Phillips GoGear Vibe.
