Question about AO Smith Pool & Spa
Starting capicator e plus 717745203 ao smith - AO Smith Pool & Spa
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
  • 24 Answers
SOURCE: capacitor wiring on a ao smith M#-C48L2N134B1.
The single lead goes to one leg, the split wired leg in the same spade goes to the other. They are usually yellow wires. As far as Hayward, Jacuzzi and Starite are concerned.
Posted on Dec 17, 2009
al_kupchella
  • 843 Answers
SOURCE: I have a A.O Smith 2 HP motor. Is there any way I
Sorry, but no. Reversible AC motors are very different. Without that design difference (which adds cost) you can't reverse it. Your label is telling you that you don't have the special kind of motor.
Posted on May 14, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
Posted on Aug 23, 2010
john224
  • 1378 Answers
SOURCE: My pool originally had a
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
Posted on May 24, 2011
What capacitors do i need to get to replace the ones on a 6 hp motor
Due to the nature of power factor correction and other sizing criteria it is best to open the can on the motor that protects the capacitor and order a comparable unit for capacitance, number of sections (- ie, start/run versus Start or Run) plus capacity and working volts AC. Unless ordering from the original compressor supply company, most parts houses will not have a cross reference with that data.
Jan 31, 2012 | AO Smith 6 Hp 3450rpm R56Y Frame 230 Volts...
I have a Whisperflo Eplus 1.5HP pool pump. It has a A.O. Smith motor. the 50MFD 370VAC capacior is bad and needs to be replaced. Is the Capacitior a run capacitor or a start capacitor? Does it make a...
You didn't indicate exactly what AO Smith motor model you have, but most likely it's Capacitor start/run if it doesn't have a switch. The important thing is to replace with the same MFD as the old so you have the same starting characteristics. Here is a great link on AO Smith motors: http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Aug 13, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Dead motor on shopcool model# sc3500 are repklacement motors availiale
This unit was made by AdobeAir in Phoenix which has gone out of business. You're in the same boat as all the people looking for replacement motors for their MasterCool MMB10 MMB12 and MMB14's.
You can try to have the motor rebuilt at a motor repair place but I have no idea as to the cost.
I posted this to another question regarding the MasterCool units.
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Jul 29, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Motor is frozen.
Unlessyou can find an HVAC shop with a NOS motor for this unit you will notfind a drop in replacement. Even if you do get lucky and find a NOSmotor be prepared to pay nearly as much for it as you would a whole newevap cooler.
It'sstill a little spendy, especially if you want two speeds like theoriginal motor had, but you can get out for $80 or less if you'rewilling to settle for one speed (on/off).
Basicallywhat you're looking for is a "48 frame", 1/8 hp, direct drive,110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to giveyou flexability when mounting), "totally enclosed" or "open drip-proof"housing (NOT "open"). Rotation can be either CW or CCW as you can mountthe motor on either side of the housing and some motors are reversable.If you've got the skill to custom make some mounts then you canprobably fudge some of these specs. The ones you can't change are the1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assemblysimply can't be made to go much faster in that housing and if you tryyou will overheat the motor and burn it out very quickly (trust me onthis one!). Most of the cheap motors I've found are 208-230v and I justdon't see the point in having a small 220v PORTABLE evap cooler, that'sjust dumb.
After a LOT of online research I've found thefollowing motors that would be a suitable replacement, with all theabove mentioned specifications. I'm sure there are more, but crossreferencing this information for someone not in the business is trickyand time consuming.
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Isuppose that if you found a smoking deal on eBay for an "Open" typemotor you could try it, but I doubt it would last long and make damnsure that ****** is grounded well.
Jul 17, 2010 | AdobeAir Evaporative Cooler Direct Drive
I need a 1/8hp 115v 1075 2sp swamp cooler motor
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 06, 2010 | AdobeAir Mobile Swamp Evaporative Air...
The motor has burned out. I need a replacement. Where can I get a new motor?
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 05, 2010 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
Have a master cool MMB10 and all of a sudden the fan runs slower on both speeds. Motor bad or something else?
Mine did that too. Either the motor needs to be cleaned out or the motor is shot. You can try to have the motor repaired. If that fails a replacement motor is about $120 if you can find one.
I posted this to another solution for someone looking for the motor:
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Jul 04, 2010 | Mastercool Portable Air Conditioner
Need replacement motor for a model MMB10B
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Aug 07, 2009 | Mastercool Portable Air Conditioner
Pool & Spa Logo
26 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
