I have a trane twe036c140b0 and it will not switch too emerganecy heat automatically?
2 Suggested Answers
hvac1
  • 338 Answers
SOURCE: My Trane TWE036C140B0 is not
Sounds like your compressor is not running check your run cap. Most tranes I work on has a start cap it will be a black color and the run will be a shiny silver. If you have a multimeter you can check the caps. You will need a meter that has micro Fards and the caps have the ratings written on them.
Posted on Jul 30, 2011
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
Trane TWE036C140B0
Is it just the indoor fan that runs constantly? Have you checked the fan switch at the thermostat? Make sure it is set to Auto.
Apr 11, 2014 | Ruud Central System Air Conditioner
Trane xr12 heat pump switching to aux
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
Apr 30, 2017 | Heating & Cooling
My Trane TWE036C140B0 is not blowing cool air i have turned off the TSTAT and still not getting any cool air the outside fan is working and the lines are not frozen
Jul 30, 2011 | Ruud Central System Air Conditioner
When turning on heat after a period of using air
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
No Back up light.
Those two connectors are your answer..
One is so the car will only start in Park or Neutral.
The other is the reverse switch.
Do they both have wires going to them, if not, find the wires and plug them back in..
Alternatively your switch might be dead and need replacing.
Jun 13, 2009 | 1984 Toyota Corolla
Trane XL19i 8? ton heat pump not heating very well
Your second stage heat check the dip switches on the board and the wires to the proper two stage heat t-stat.
Feb 06, 2009 | Omega Trane Furnace Draft Inducer Blower...
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
