Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
What does it mean when pronto m41 flashing lights 8 times
3 Suggested Answers
  • 692 Answers
SOURCE: I have an Invacare Pronto
mad check the freewheel levers under the front of the seat on the base make sure that they are in the drive mode turn the chair on and you should be good to go. Have the power off move the levers back and forth and leave in the drive mode then turn the power on and you should see normal lights and operation Hope this helps
Posted on Apr 07, 2011
  • 68 Answers
SOURCE: wwe have a pronto m41 mobility chair.the service
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Posted on Apr 30, 2011
Wrench flashes 6 times on invacare pronto m41 which means a right brake lever fault. How do I fix it?
Push it in and pull it out a few times to make sure it is in position. If not pull the wheel off and make sure your connections are tight.
Jul 25, 2016 | Invacare Health & Beauty
Yellow blinking light what does this mean on pronto M41 invacare?
The AMBER service indicator will light when an error or fault occurs. This is a yellow wrench shape. Refer to Diagnostic Codes on page 33 for a listing of the flash codes and what they indicate:
https://www.phc-online.com/v/vspfiles/V4_Backup/docs/MK5-NX_Electronics_Manual.pdf
Mar 10, 2015 | Invacare Pronto M51 Power Wheelchair
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
Jan 23, 2015 | Electric Mobility Invacare Pronto M41...
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
A Pronto M41 w/ SureStep was given to my Best Friend who has stage 4 cancer throughout her body. It seem to charge fine but a yellow wrench light comes on. Because it was given to her how can I how and...
Since time was important this may be too late.
1. You can download manuals for pretty much anything by asking Google for something like 'Pronto M41 manual'. Manuals help a lot.
2. Googling 'wheechair repair [your town]' will point you to people who can service the chair. You can also contact a local agency for people with disabilities for ideas.
May 07, 2014 | Electric Mobility Invacare Pronto M41...
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
Catalina powerchair 8 wrench flashes
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
Dec 21, 2013 | Electric Mobility Pronto M41 Power Chair...
Blinking wrench light on an invacre pronto m41 power wheelchair, what does this mean?
Hello,all the info you seek will be found in:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Download it as a PDF File,36 pages full of info.Page 19 to 36 focuses on what you ask for.I am sure you will be happy with what you see,take care.Colin
Apr 22, 2013 | Invacare Pronto M41 Power Wheelchair -...
We are trying to move the chair and the service light keeps coming on
The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
Aug 25, 2010 | Electric Mobility Invacare Pronto M41...
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
116 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
