Question about Sakar Crayola EZ Grip Digital Camera
The display screen is not working.
It seems all functions are working, but the screen is no longer showing pictures or anything else. I changed the batteries but that didn't help. Any ideas on how to fix this?
  • 734 Answers
LCD screen can be replaced cheaply if you buy parts camera from ebay. You need a 000 philips screw driver to take it apart to replace the screen.
Posted on Feb 08, 2012
Display does not show any view
You know you can change the monitor brightness? Check the manual (eventually online) to see how to change the settings. Please check if you can playback pictures you already shot, to make sure the display still works.
You also could remove the battery, charge it and then replace it. This acts like a cold boot from a computer.
May 24, 2014 | Olympus FE-210 Digital Camera
Olympus Stylus 1030 SW display not working after being in water
I just had a similar problem. I am not sure how it was fixed, but it works again - at least for now.
I had the camera on and was taking pictures when the screen went dark. Same as you describe, it takes pictures, flash works, LED, works, everything but the display. I plugged it into my computer with the USB adapter to see if I can salvage what is on the card and the diplay lights up. Tried several variations, but when the cable is connected to the computer (didn't have to be connected to the computer) the screen worked. Unplug, no display. I spun the settings button a couple of times. I accidentally took a couple of short videos and pictures that I deleted. I unplugged the camera and powered down again (tried that before). Power up and the screen is fine.
Again I have no idea what fixed it or why the display worked with the cable plugged in. It might have been related to the videos or some setting that I had slipped into (thought the display button never worked or changed anything).
Hopefully something in there helps or someone can explain what I did.
Oct 18, 2009 | Cameras
My Nokia N70M goes Blank, LCD is lit, but cant see anything!
u have a display problem ur display needs to be changed
Sep 01, 2009 | Nokia N70 Cellular Phone
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Kodak v550 easyschare camera
As long as the pictures look fine it is something going on with the lcd display.
If it was taking pictures the same, it could be a special effect that is turned on or the CCD is bad. It sounds like the LCD display is bad. Some cameras can be repaired at a reasonable price with a new LCD display.
Have you replaced the batteries in the camera? That might take care of the problem.
Jun 15, 2008 | Kodak EasyShare V1003 Digital Camera
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Partial display of functions
Faulty selector switch, may be able to fix if you have the skills, remove back cover and bend out switch contacts slightly
Oct 03, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Sakar Crayola EZ Grip Digital Camera Logo
410 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
