Question about Microsoft Xbox 360 Console
Conncting a projector to xbox 360
I have an old stlye sony lcd projector, it only as monitor connections on the back, i purchased a monitor/scart connector so i could watch dvds on my dvd player, i now want to connect my xbox 360 to this projector is it possilble?
    Sniper:
  • 122 Answers
Yes it is possible, you need a cable with the VGA adapter on the end, such as this one
Posted on Mar 22, 2010
    Problem Solver:
  • 10 Answers
You can get a VGA cable for your xbox
Posted on May 22, 2009
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
Tip
How to set up your xbox 360 without causing overheat
take everything out your new xbox 360 packaging. there should be:
1)a console (obvioiusly)
2) a cable that connects your 360 to a power block
3) a power block that connects your xbox to the wall
4) a cable that connects your xbox to the tv
5) a small rectangular box that connects your cable into the scart port on your tv.
lets begin
take the cable and connect it to the power block and move the power block to the side
take the scart plug (small rectangular box) and connect the yellow white and red wires into the approprite slots (these are marked out on your scart plug) and move to the side
pace your console down 90 deg. on its side in your desired position.
WARNING WARNING WARNING WARNING WARNING WARNING WA
do NOT place your xbox 360 standing up as this can cause red ring of death syndrome and other known xbox killers due to overheating i am on my second 360 as i never followed my own advise.if you keep your console standing straight it can cause vibrations which knock your cooling sinc out of place. it can also scratch your games more easily and ring them making them UNPLAYABLE. now place all cables you set aside and connect them into appropriate slots on the back of the console. and connect them into wall socket and tv.
thanks for reading.now wheres the free cake i was promised.
on May 15, 2010 | Microsoft Xbox 360 Console
How to connect xbox 360 to Vaio pcg 252l
I couldn't find out if the Vaio pcg 252l was either a monitor or laptop, but if it is a laptop, I have to dissapoint you because there is not possible to do, because the laptop isn't made to be used as a monitor, but if the Vaio is a monitor(basicly a screen), then all you have to do is to either connect a HDMI cable from the xbox to the monitor, or you can use a SCART cable, all depending on which are available on the monitor/xbox.
HDMI have better quality, in case you could use both cables.
Oct 13, 2012 | Sony Used Vaio Pcg-252l Vgc-ls25e All In...
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Xbox/TV
Try using a scart switch, therefore you only have to use a basic scart lead from the TV to the switch. then plug your xbox scart into the switch and it should work
Nov 03, 2008 | Televison & Video
Xbox 360 HDMI Audio Analog
http://forums.xbox-scene.com/index.php?showtopic=415408
Jan 07, 2008 | Microsoft Xbox 360 Console
How to change from PAL-50 to PAL-60?!
i have a xbox 360 and a television that opperates at PAL-50
my xbox is telling me, to play a game i must operate at PAL-60.
when i change the xbox settins to PAL-60 the televison goes all fuzzy, can i fix this.
Apr 14, 2007 | NEC MultiSync LCD1550VM 15" LCD Monitor
Microsoft Xbox 360 Console Logo
254 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
