Question about Toys
I purchased iwave eagle eye M899-15 RC helicopter but transmitter will not work or turn on. Changed batteries tried everything please help
  • 62 Answers
SOURCE: My eagle rc helicopter wont fly
replace the rotors and it will fly
Posted on Sep 03, 2009
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: how do you charge the iwave helicopter?
In the controller unit (the controller holds the 6 AA batts) there is a compartment just under the green charge light. Open the compartment by sliding the compartment door down in the direction of the arrow. This will expose a wire with a white plug on the end of it. Insert this plug into a socket found on the underbelly of the helicopter next to the on/off switch. On the controller, turn the switch to the 'on' position. The red and green light on the controller will light, indicating it's charging. After about 15 minutes, the green light will go out, indicating that the helicopter is fully charged.
Posted on Jan 04, 2011
SOURCE: I need an instruction manual for the iWave
I haven't found one on-line, but I still have mine. What did you need to know?
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Hak 735 helicopter
Usually synching requires one device started before the other, meaning that you may want to power on the transmitter, then turn on the heli and try the heli first, then the transmitter second if that doesn't work. Otherwise there's usually a small button that is pressed to get the two devices talking to each other.
Why wont my RC helicopter respond to the controller
The Helicopter channel/frequency may need changing to match the channel/frequency on the transmitter.
OR change the transmitter channel/frequency to suit the helicopter.
Feb 06, 2013 | Toys
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I need stablizers for helicopter model RC8702 sold by iwave
I'm sorry you are having trouble with your RC helicopter. Please contact us at the customer support department at: support@iwaveaudio.com.
Jan 19, 2011 | Jumbo RC JUMBO HELICOPTER
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
I'm looking for a replacement owners manual for a Exceed RC Eagle 50 Helicopter.
try contacting the manufacturer they should be happy to help to keep your business
Jul 07, 2009 | RC Exceed Rc Eagle 50 Rc Helicopter...
Receiver problems right out of the box!!
You may have to "bind" the receiver to the transmitter again. See the instructions that came with the transmitter on how to do this. If this not the problem the hobby shop is obliged to make sure it works so take it back before it get damaged.
Mar 16, 2009 | Walkera HM5#10 RC Helicopter
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
Toys Logo
341 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
