Question about Epson Stylus RX500 All-In-One InkJet Printer
Printing problem Hello, I am having a problem with my printer. Epson RX500. When I print the part where there is black or gray shadows in the a picture prints out bright yellow. The color blue is turning out to be a weird light purple. I thought at first it was a weird setting on my Photoshop program so I used a few different programs and they all printed exactly the same. I havent had this problem the whole time I had the printer, it seemed to happen right after I replaced the ink. Please help, I run a business and I cant keep printing things like this. Anything advice or help would be soo appreciated.
    Problem Solver:
  • 17 Answers
Perform several Head Cleaning cycles and do a Nozzle Check. If the nozzles are still clogged turn the printer off overnight to allow the ink to soften and then try cleaning again.
Posted on Nov 07, 2008
Epson Stylus RX500 problem: black no longer printing - have installed new cartridge, several nozzle checks, head cleaning, still no black. Any ideas?
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
I located a page on forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 31, 2010 | Epson Stylus RX500 All-In-One InkJet...
My RX500 is recognized in the device manager and says that it is working properly. When I click print on my computer...the printer cache SAYS that it's printing...but the printer doesn't respond to the...
Epson Stylus Photo RX500
Question History
Step 1 WHICH MODEL ARE YOU USING? Stylus Photo RX500 Step 2 What were you doing when the problem occurred? Printing Step 3 What happened when you tried to print? No response from the device Step 4 How are you printing? From the computer Step 5 Are any of the Mode lights on? Yes Step 6 Which message is displayed on your device's control panel? None of the above Step 7 WHAT IS THE DEVICE'S STATUS? Ready Step 8 Are you able to print your device's nozzle check using the buttons on its control panel? Yes Step 9 Do you see an error message on your computer screen? No Step 10 Which operating system are you using? Windows XP Step 11 Make sure the correct printer and port are selected in the software. Does that fix the problem? No Step 12 Reconnect or reconfigure your cabling. Does that fix the problem? No
Says for you to Contact Epson
1. Based on the information you provided, here is what you need now.
Based on the information you provided, here is what you need now. Please contact Epson to resolve this problem with a technical support representative
(562) 276-4382
6 A.M. to 6 P.M., Monday-Friday
(Pacific Time)
Thanks and Good Luck......
Dec 27, 2009 | Epson Stylus Photo RX500 Printer
first go to your start menu. Then click on Printer and Faxes. When there right click on your printer and select Properties. When this window opens go to the General tab; then go to the Color tab. There you will see a box that you can check for printing in Gray Scale Only. Check this. After you have checked it, you can then check Black only.
If you wish for this to remain that way until you replace the other colors, be sure to click on APPLY or it will only print the first thing that way. After you have replaced the ink cartridges, use the same tabs to cancel the gray scale selection!
Mar 01, 2009 | Epson Stylus Photo RX500 Printer
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus rx500 prints too magenta-ie
Try replacing the magenta cartridge...
Does it also do this when you try to use it as a copier? If so,
try to clean the head.. If it only happens when you're printing from the computer, try to reinstall the driver
Jun 30, 2008 | Epson Stylus Photo RX500 Printer
No. It needs them all to present and with ink in. Otherwise it will do no printing.
Jun 20, 2008 | Epson Stylus RX500 All-In-One InkJet...
Printer not printing Epson Stylus RX500
What does the error in the status monitor report?
Switch on the printer, and under Printers And Faxes in windows right click on the RX and select properties
Click on Printing Preferences and then select the maintenance tab, select the Status Monitor and report what it says in the box in the middle.
From here we will be able to help you.
Oct 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Epson RX500 printing problems
Please go to my website . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Oct 15, 2007 | Epson Stylus RX500 All-In-One InkJet...
Printing black and white
try a few head cleans or it could be cheap catridges dont refill them, and dont buy the cheap nasty catridges
Jun 28, 2006 | Epson Stylus RX500 All-In-One InkJet...
Prints fist lines onlyTrying to print a list
Clean the head - first in control panel, doubleclick on 'printers and faxes' then right click on your printer and click on printing preferences then when the window opens up on your left at the top - click on maintenance to clean the head.
May 27, 2006 | Epson Stylus C66 Inkjet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
