Question about Radio Communications
Just bought a nice looking galaxy dx44 but will not power on, is there a fuse or maybe a resistor that got blown from hooking up the power backwards?
Checked solder connections with a ohm meter but can't find a problem. Noticed the external power plug has only 2 terminals not sure if that is correct. Getting power to the 1969 final?
    Genius:
  • 1,212 Answers
If power was reversed, there is a 1N4007, 1N4003, rectifiers, 2 1000 microfarad 25 WVDC capacitors, a filter choke and a common mode noise filter that are likely to have taken the brunt of it. The choke likely burned out.
2 power leads is all it needs- one positive, one negative/ground.
It should have a 2SC1969 final C1969 should be the same.
Posted on Feb 08, 2012
2 Suggested Answers
  • 773 Answers
SOURCE: Just want to know where to set all the bottoms on
With out a frequency counter to tell you what freq you are transmitting on there is another way.
Turn to channel 19. mess with the switches untill you hear truckers on the highway. then you have got it.
Otherwise pick up a frequency counter on ebay.
Posted on Oct 17, 2009
Fuse blew when I hooked up speakers.opened up my durrabrand ht-400 and seen it caught fire a little bit.can this be fixed,and if so,how. Need help
From your photo it looks like the power transistor is blown up
5_4_2017_7_22_32_am-fqpri0tghtom2qr1ml2b2auw-4-0.jpg You may need to follow the circuit tracks and see if there are any other components blown up Maybe the resistors or capacitors
You need to ask yourself why did the speakers blow this up maybe there is a short circuit in the speakers ?
May 04, 2017 | Audio Players & Recorders
Tip
GET YOUR BLOWN UP RADIO BACK ONLINE.
When you cant get your radio turned on. All it does is blow the fuse imeadiatlly hooking it to power. Most likely it is the (reverse polarity diode). The quick fix is to locate your diode? This diode usually is back behind a coil wound transformer on your board inside the radio and in the general area of where the possitive ans negative plug wires solder to the board! Usually it is black with a silver band around one end. If you clip it on one end or remove it this will restore your radios power. CAUTION:: When doing this ALWAYS use a dual fuse power cord . This will prevent this from happening again by blowing the fuse first. Doing this procedure will remove your thermal protection to the radio thus making it wide open to being fried for good if it ever gets hooked up backwards again. This is my reasoning for the dual fused power cord. Good luck!
on Mar 11, 2015 | Galaxy Radios Radio Communications
Is there a diode inside a galaxy dx99v that could be blown and not letting it turn on ?
Yes there are diodes in the power supply, but it could be a fuse, resistor fuse, or a bad switch, a host of things. You need to take it to a tech unless you have schematics an a good VOM.
Apr 24, 2017 | Galaxy Radio Communications
Full electrical power loss to everything.
Were the cables accidently hooked up backwards ? The main fuse at the fuse block may have blown. Check where your positive cable hooks at the main fuse block and there should be a fuse rated over 100 amps for the fuse block feed.
Jul 31, 2015 | 2004 Chevrolet Chevrolet Impala
Hooked power up backwards on amp
Likely there is a reset period for an internal safety. If you can open it up you will find either something obviously burnt or it's probably O.K. A "diode" only lets power go one way. If reversed it shouldn't fail. More likely fried resistors. Too small to see if they're inside a chip, but easy to see if soldered on a circuit board. The color of the stripes on the resistor indicate it's exact type.
Apr 09, 2015 | Car Audio & Video
Hooked up battery backwards must have blown a fuse where is it located 05 yzf
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Where the fuse box
yzf600r main fuse location Google Search
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Dec 06, 2013 | 2005 Yamaha YZF 600 R thunder cat
I accidentally hooked my battery up to my bike backwards and put a jump starter up to it backwards as well. When I started to smell the battery I realized my mistake. I hooked it up correctly and it...
May have a blown main fuse or several fuses. The larger main fuse can be located around the battery and even sometimes in the fuse panel. Hooking up the jumpers backward may have also cause electronic damage to things like the ecm, ignition modul etc. If the damage is electronic is may be major so carry it to a shop and let the shop look at it.
Nov 15, 2012 | Motorcycles
Picture looks like hour glass.
You're probably talking about bad convergence. Probably Convergence power board. Only $20-$30 from encompassparts. com, if still available.
Apr 17, 2010 | Televison & Video
Blowing fuses when power is hooked up
once you've done this, hooked up a radio backwards, you have to change the resistor...take it to a shop I only charge $18
Nov 26, 2009 | Cobra 29 LTD CB Radio
I have sound but no tsmt,the tsmt light does comes on,no output
well that leaves 2 mor parts the transmit final and the current resistor these have straight 12 volts applied when the radio is turned on . if you look at the final it will be burnt or blown apart on the heat sink. replace them and you shoul be up and talking again.
Mar 08, 2009 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
