Question about Vizio E420VO 42 in. LCD HDTV
Vizio 42" TV HDMI ports only not working, other inputs ok
SOURCE: green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Posted on Jan 09, 2008
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I have had my tv got blank a couple of times.. at the HDMI connection.  Seemed to be software.  I unplugged the HDMI and turned off and unplugged both devices (tv and dvd) then turned them back on.. problem solved.
Posted on Jul 02, 2008
  • 300 Answers
SOURCE: vizio 42 hdtv lcd no power
lol , technicaly it's not possible to plug a USB PORT , into an RJ45 Phone Jack lol
But lets assume he did manage to do just that.
A. Land Lines in the united states phone system use -48 volts of electrical power.
B. USB ports that provide power to USB devices use +5 volts of electrical power.
What you have described to me would suggest to me that your USB port has been overloaded
by the input of a much higher voltage sourse ( the phone line )
Some suggested steps
1. completely unplug the computers power cable for approximately 15 seconds.
2. plug the computer back up and press the power button.
If this fails you may now have a defective motherboard or a blown power supply.
You have some options at this point.
You can change the power supply and see if that solves the issue
If a new power supply does not solve the issue
you will need to change the motherboard.
My advice on changing the motherboard is that you replace ONLY the motherboard first.
If more things like the Memory or CPU are dammaged , you will then replace them as needed.
I feel very dissapointed that your son was unable to accomplish his computer hacking goals lol
perhaps when he is older he will make a fine Engineer.
Thank you for using FixYa!
Az.
Posted on Sep 19, 2008
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
SOURCE: what is rgb mode?
help
Posted on Sep 29, 2009
Vizio E420I-A0 no sound on hdmi
Try a firmware update. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 22, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
Viore 42" (PDP42V18HA) HDMI WOES
More than likely you ruined the HDMI circuit. Over twice the required voltage is never good.
Jul 11, 2016 | Vizio 42" viore pdp42v18ha 720p widescreen...
Blew out HDMI on Vizio 42
Please go for a multiple selection switch box.
Aug 19, 2012 | Vizio 42 in. LCD TV
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
My vizio sv420m hdmi ports stoped working
Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Vizio 42 in. LCD TV
Two of three HDMI input ports are not working. Only the side port is funtional.
Your signal board is bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 23, 2011 | Vizio 42 in. LCD TV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
42" Vizio LCD
Emilie, I have the same issue. I have to press the input on the TV to go through all of the inputs and whenI get back to HDMI 1 it usually goes back to nomral - but sometimes that doesnt even work. I tried calling support, but waited 40 minutes and hung up. chris
Jan 06, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio E420VO 42 in. LCD HDTV Logo
136 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
