Question about Acer Aspire 3050-1733 Notebook
Acer aspire 3050
When i insert a cd and try to rip a message appears you need a cd drive to rip! i have managed to locate the drive and it will not load saying code 10
I am trying to boot windows 7system recovery onto a usb flash drive .when i push it into the laptop it says bootmgr is missing.how do i fix that
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Oct 20, 2010 | Acer Aspire 3050-1733 Notebook
CD-RW driver disappeared
check the cable connections to your optical drive..it must have loosen up
Sep 05, 2009 | Acer Aspire 3050 Notebook
CD drive no longer exists
Try reinstalling The Driver..http://us.acer.com/acer-v2/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Jul 22, 2009 | Acer Computers & Internet
Computer does register wen i put a cd in the tray
Hi try rebooting the laptop or if that doesn't work you may have to search of another drivier for the E: drive.
It happened to me ages ago on my acer aspire 5100/5102 wlmi
Apr 02, 2009 | Acer Aspire 5315 Notebook
Cdr/dvd rom not recogniced by acer aspire 3050
wow. I would reinstall cd/dvd driver see if that worked.
Not really much else it could be. Unless our losing the drive.
Comment me back let me know how it goes.
Good Luck!
Mar 12, 2009 | Acer Aspire 3050-1733 Notebook
Acer 5100 cd/dvd drive no longer appears as a device - anywhere
try a disk cleaner it might be dirty inside and they are very sensative
Dec 21, 2008 | Acer Aspire 5100 Notebook
Acer 5315 elock
Go to device manager and click on your dvd/cd drive. Double click on this and enable the drive.
If driver is missing, go to Acer's website and download your dvd/cd device driver.
Dec 08, 2008 | Acer Aspire 5315 Notebook
My Acer Aspire 5002WLMi Laptop is not reading any disks put into its CD drive. The Disk icon is not even appearing.
First question: What are the circumstances that led to this issue? Has the Acer Aspire ever read any disks in its cd drive? What happened before this occurred? What are the sounds/beeps you hear when the cd is inserted into the disk drive?
If you can go into the device manager (click on My Computer--Properties----Device Manager---go to the cd/dvdrom drive. What do you see? ex. if there is a red x, that mea your laptop is not recognizing the device...) Let me know when you have examined all the questions above, so I can help you solve this issue.
Nov 16, 2008 | Acer Computers & Internet
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Cannot open DVD disc
Brain,
Is your drive supports DVD? Try to put a CD disc and see its reading or not. If this problem occurs for both CD's and DVD's discs then you might have problem in your drive lense. and if it only reads CD then your drive might not be supported for DVD's.
try to clean your drive lense using CD head cleaner, it might solve your problem, other than you have to replace your drive.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire 5580 Notebook
Acer Aspire 3050-1733 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
