Question about ASUS ALi Chipset A7A266 (A7A226) Motherboard
Will not boot to bios or beep - ASUS ALi Chipset A7A266 (A7A226) Motherboard
  • ASUS Master
  • 27,725 Answers
BIOS is a software program that controls basic functions in your computer, such as boot order, keyboard control and how your processor interacts with memory cards. If you get an "NTLDR Is Missing" error, inspect your BIOS utility to make sure your computer is booting up from the right place.
Cmos is located in BIOS
Restart your computer
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
if you need to change any of the settings using the arrow keys you can load failsafe or optimised defaults
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps you
Posted on Feb 09, 2012
Operating systems doesn't boot (BIOS beep codes)?
Do you have video going to your monitor? If not the beeps mean you have a bad memory stick in there. If you have video the beeps are the bios telling you that its not set right. More than likely you have it set to run too fast. Go into your bios find where the processor speed is located and choose a lower freq. rate. Its probably set too high for the memory you have.
Jun 22, 2012 | AcerPower F2 PC Desktop
When i boot up my computer it beeps like 25 times and then it freezes it tries to boot windows
What brand the laptop is?
How many beeps are short and long and in what sequence?
Do you receive any error?
When the computer starts it checks its hardware and proceeds to boot the OS (windows). If it finds a hardware fault it will beep a code and stop there. The beep code may depend on the fault itself (video, memory, etc) and BIOS brand (Phoenix, American Megatrends, etc). You can try entering the BIOS by holding the or keys as soon as you turn it on for about 5 secs while it shows the first logo on screen. Then in BIOS you can see whats the brand of the BIOS is and with that info search for the beeping codes for that BIOS brand. That will say what kind of fault the unit is having. I hope this works. Im new in this FixYa so I dont know if you can reply me with the answers.
Mar 25, 2011 | Computers & Internet
Powers on for 5-6seconds then beeps one time and shuts down
Here are the beep codes for common BIOS programs:
1 BeepA single beep from an AMI based BIOS means there has been a memory refresh timer error. The solution is often to replace the RAM in the computer.
A long beep from AWARD is probably memory error.
1 short beep from AWARD bios & PhoenixBIOS and most others is a positive ok signal.
Without more information, it sounds like it is a memory problem. Remove the memory and see if it will boot to the BIOS/setup screen. If so and you have multiple memory sticks, put one in and try to boot. If that fails try the other.
Aug 20, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
Motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
The name of your BIOS should appear on the monitor as you're booting.
Nov 20, 2007 | Asrock M810LMR Motherboard
ASUS ALi Chipset A7A266 (A7A226) Motherboard Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
