Question about HP Pavilion dv6000z Notebook
Hp pavillion laptop dv6000
My problem that the icon of dvd driver disappear suddenly
  • 186 Answers
I beleive that the DVD Drive icon had dissappeared from My Computer.
However, I recommend you to check in the Device Manager by clicking the + mark next to DVD/CD-Rom Drives.
If you find any entry under the DVD/CD-Rom Drives, right click on the entry and select Properties.
In the Properties window that opens, check the status of the drive listed under Device Status.
If you find any error message with Drivers, we need to make some registry changes to reinstall the Drivers for the DVD Drive which should solve the issue.
Since you had not mentioned the Operating System installed in the Notebook depending on which the steps to edit the Registry depends, I am providing the steps for both XP and Vista :
Uninstalling DVD Drive Drivers from Registry in XP :
http://support.microsoft.com/kb/314060
Follow the instructions listed under Advanced Troubleshooting to edit the Registry in XP
Better way is to copy the entire link and paste it in the address bar of a new Interner Explorer window and press enter key.
Uninstalling DVD Drive Drivers from Registry in Vista :
http://support.microsoft.com/kb/929461/en-us
You may either find the Upper or Lower Filters or Both as per the instructions provided in the links above. Delete the Upper and Lower Filters which ever you find from the Registry and restart the computer which should solve the issue.
However, if there is no entry of the DVD Drive even in the Device Manager, you may have to remove and reinsert the Drive manually as it can be an issue with the connectivity of the Drive with the Notebook.
You can find the instructions to remove and reinsert the DVD Drive from the manual of the Notebook which can be found from the link provided below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructiosn to remove and reinsert the DVD Drive in the Notebook starting from page number 110 of 233 in the Manual.
However, if there are no error messages in the DVD Drive properties window in the Device Manager and if the DVD Drive icon is missing from My Computer window, all you need to do is to try changing the Drive Letter of the DVD Drive from the Disk Management window.
Find the instructions to change or assign a Drive Letter to the DVD Drive in XP from the links below :
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=no&dlc=no&cc=no&docname=lpg40244#N545
http://pcsupport.about.com/od/tipstricks/ht/changedriveltr.htm
Find the instructions to change or assign Drive Letter for the DVD Drive in Vista from the link below :
http://www.tech-recipes.com/rx/506/vista_xp_reassign_change_drive_letters/
http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm
I am sure that any of the instructions provided should solve the issue with the DVD Drive in your Notebook.
Posted on Oct 24, 2008
Im using hp pavillion dv6000 today i could not
The Windows administrator or users password can be removed or changed with the Hiren's boot CD - Click on one of these link to download.
http://www.hirensbootcd.net/ or http://67.20.82.163/
Use a computer that has Internet access and download and burn onto a CD. Then boot-up this CD in your computer and select password removal and follow the instructions.
May 13, 2010 | HP Pavilion dv6000z Notebook
How can I tell if my HP Pavillion dv6000 can burn DVDs? I tried to with DVD Flick but the dvd came out blank after 3 hours of supposed burning.
Try creating a normal CD-R for example just a picture using windows transfer which is simply double clicking your CD drive icon in my computer dragging a picture on to it then burn the files should be on the left, if so then your burner should be fine. I Would suggest using NERO to burn DVD's
G
Feb 19, 2010 | Computers & Internet
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
Hp pavillion dvd burner
download the dvd then access the file and put in a blank disc and select that file
Nov 17, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
After startup, all icons and taskbar disappear...
start your machine in safe mode and if you have any antivirus installed in it and is updated then scan it , your laptop is infected with virus . so scan it
Apr 25, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
186 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
