Question about Dell Inspiron 2200 CD-RW/DVD Drive Combo - GCC-4244N Burner
Where is the battery in my laptop so I can replace it
My laptop says i need to replace battery but I cannot locate where to take the old one out.
    Guru:
  • 154 Answers
What type of laptop do you have?Access to most batteries are located on the bottom of the computer or on the side where you can pull it out.
Posted on Feb 08, 2012
Not powering on
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Jan 15, 2013 | Dell Inspiron 1521 Laptop
HP Pavilion g-7 will power on, Fans on, No screen, Nothing else
you have posted in webcam problems !! you might be better posting in laptops
Jan 09, 2013 | HP Pavilion G7-1167Dx Laptop / Amd Phenom...
Will not turn on
Is it on?
hope this helps
Oct 22, 2012 | Dell Latitude D610 Notebook
Computer wont start in any mode, black screen
Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have 1.lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
2.Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
3.Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
4.Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
5.Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
6.Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
7.Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws.
Sep 28, 2011 | Computers & Internet
Problems with new laptop battery for my Acer 6920G.
You can't force the battery with a higher charge to work without damaging the computer. If the battery is a direct replacement it should work. If your original charger is not capable of charging the battery you can consider a charger replacement but I suspect the original charger you where using was bad to begin with if that is the case. You can try locating a replacement charger but you need to make sure it is rated for computer so you don't damage the power system.
Jun 20, 2010 | Acer Aspire 6920 Notebook PC
Need to dispose of old battery
Sometimes the battery vendor will take back batteries and properly dispose of them.
You should not put them in the garbage, they have to be returned to a hazardous waste depot.
Where are you located?
Jan 06, 2010 | Sony Computers & Internet
Need to change battery
http://h10032.www1.hp.com/ctg/Manual/c00326469.pdf
This is a link to the owner's manual. It shows pictures of the laptop and where the battery is located. Probably easy to find a replacement battery on ebay.com or elsewhere. The battery should have a number on it for reordering or you can find one at www.hp.com
Oct 01, 2009 | HP Compaq Presario 2200 Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
How to replace a compaq presario 1255 cmos battery
You have to take the case apart and find the old battery.It sounds like a large tast but you can pull it of in about 20 min.locate all the screws on the underside of the keyboard part of the laptop remove the main battery as ther may be a screw or 2 in the battery case once you are sure that you have removed all of the screws try seperating the 2 parts of the case sometimes they have clips that snap both parts together you can loosen then with a flathead if you find them by pressing inward and releasing them.once you have opened the case locate the battery and replace it .YOU CAN DO IT!
Nov 17, 2007 | Computers & Internet
Dell Inspiron 2200 CD-RW/DVD Drive Combo - GCC-4244N Burner Logo
47 people viewed this question
Alun Cox
