Question about Amana NED7200TW Electric Dryer
Amana ned7200tw error code 10
Drum turns but never gets hot...diagnostic error code displayed is 10
  • rick boone Feb 08, 2012
    found that the heater coil was broken it tested open and when i took it out found a broken coil
    now i need to know the place to order replacement onlline
  • 2122 Answers
SOURCE: my amana ned7200tw electric dryer turns on but
all there is is a belt that turns the drum,the belt goes on the motor pulley around the pulley and around the drum, check the motor pulley to see if it unattached from motor shaft or check the belt to see if it flipped over somehow,there is a smooth side and a ribbed side on the belt and you said the pulley is fine
Posted on Nov 07, 2009
SOURCE: unexplained dryer noise
I have this same problem, how do I get to the belt to check it out?
Posted on Mar 28, 2010
livewire874
  • 618 Answers
SOURCE: My dryer is an Amana #NED7200TW and I got a code
HE shows up because there is no heat . Check the fuses in the panel and the heater itself. Also could be the sensor is not working to tell the control to turn the heater on.
Posted on Oct 29, 2010
heatman101
  • 43501 Answers
SOURCE: My Amana NED7200TW runs but will not heat up. I
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Posted on May 10, 2011
SOURCE: TS error unresolved on ned7200tw
my dryer is barely over 2 years old, it has stopped working and is flashing ts, we cleaned the filters and replaced the thermistor sensor, but it is still not working and flashing ts. i dont know what to try now, i know if i have to replace the dryer it will not be an amana, or any other brand associated with it.
Posted on Jul 16, 2011
My amana dryer model #NED7200TW turns on and the motor runs nicely but the drum wont turn on its own. It will turn easily if i turn it with my hand. only about 3 years old.
if your saying theres a motor running but the drum wont turn . then id say either the idler pulley has come off or drive belt has broken , these do go bad especially on heavy load machines
Sep 14, 2016 | Amana NED7200TW Electric Dryer
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
It keeps showing an error code C0. what does this mean.
Hi, I cannot find this error code for your dryer.
Does the dryer have other faults?
The Technical manual for the drier shows error codes, but does not include CO. The manual will help with resolving problems you may have as it has detailed instructions for troubleshooting and the solutions. See the diagnostic tests. You can also clear diagnostic codes, which may resolve this problem if there are no other problems with the drier.
You can download the manual from
http://www.manualslib.com/download/763426/Amana-Ned7200tw.html
Hope this helps you :)
Mar 04, 2015 | Amana NED7200TW Electric Dryer
Dryer not running, just getting a click.
check you drum belt. if belt is broken nothing will come on.
Feb 25, 2014 | Amana NED7200TW Electric Dryer
T5 error code
test the thermostat and thermistor too and replace, if the problem persist, clean the ducts, or need to replace the control board if the problem . If the problem continue
make this test.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Oct 01, 2013 | Amana NED7200TW Electric Dryer
NED7200tw t5 error Code
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
5. Power ON
Aug 08, 2012 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Unexplained dryer noise
Mar 21, 2010 | Amana NED7200TW Electric Dryer
My amana ned7200tw electric dryer turns on but doesn't tumble/run... the pulley is ok checked that any other ideas
Nov 07, 2009 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
218 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
