Question about Cobra Radio Communications
Have a 959 galaxy that will not transmitt
Will receive but will not transmitt
    Genius:
  • 1,212 Answers
It could be the switch or the relay to look at first- See if the relay contacts close- if not trace that circuit, it might be a defective microphone switch.
If you do get relay action, check for voltage at VR10, VR12 and VR14
These are biases, so they may not be "high" voltages when using an analog meter.
If you have voltages, the final is likely dead. If you do not have voltages, tie to look for bad solder joints and broken resistors.
Posted on Feb 08, 2012
Testimonial: "put in another car and it is transmitting but the needle does not go up but does work when receiveing"
  • 22 Answers
SOURCE: i have a galaxy dx 959 it keys up has no soundor receive
Try a different mic, they CAN cause no sound (receive), and no talking. If that isn't the issue, I'd go to my coax cable, even though they don't look broken doesn't mean that they aren't. I've seen quite a few brand new ones that are bad right out of the box. If all of that checks out I'd grab an SWR/power meter and do a check to see if the radio was registering on the inline meter. I'd say use the one on the radio, but I'd like to see it on the inline so you can really tell whats going on with the radio. I think I'd also get a spare radio, or a friends, and put it in my vehicle and see if it gets out. That would be the best way to check your coax and antenna setup. Aside from that, which is just simple cb logic, I'd say you may possibly have to bring the radio to a tech and have them check it out. I have a DX-959 and a DX-99V and I gotta say, knock on wood, no issues with either one. I really hoped that helped and let me know how things turn out. Its always good to hear from people after they figure out what was wrong, that way we all learn...
Posted on May 14, 2009
Benimur
  • 6966 Answers
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
SOURCE: GALAXY 959 CAN TRANSMIT BUT NO RECEIVE
try the external speaker /if that is not working you may need put in a new receiving chip it is on the right side has 10 pins.
Posted on Jan 05, 2009
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Posted on May 03, 2009
  • 100 Answers
SOURCE: My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
Posted on May 01, 2010
Need wiring help for Galaxy 959 Cb Mic
1) shield / ground 2) yellow/ audio 3) red / transmit 4) white / receive
Mar 17, 2013 | Galaxy Radios 959 40 Channel Am/ssb Radio
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx 959 radio wont transmitt
I would suspect mic first possibly broken solder connection at jack that inserts into radio.
Jan 06, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Can I tune my galaxy 959 to receive police chanels
Not a prayer of doing that. you could get a scanner and put it next to the Galaxy.
Dec 18, 2012 | Radio Communications
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Jan 03, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Radio Communications Logo
147 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
