Question about Panasonic CQ-C8100U CD Player
Panasonic cq-c8100u installation
I've hooked up every wire according to the diagrams. i have yet to get power to the actual cd deck its self is there alternative way i can get power to the deck?
4 Suggested Answers
  • 2318 Answers
SOURCE: panasonic cq-dpx152u wiring diagram
Click here to download the user's guide and go to page # 28 for the wiring connections.
Posted on Mar 11, 2009
  • 8 Answers
SOURCE: what color wire's do i match when installing and
Go out and buy the recomended wire harnes from a car audio shop. It will save you time and money in the end.
Posted on Sep 15, 2009
saailer
  • 1868 Answers
SOURCE: Have a wiring harness for a CQ-C8100U panasonic CD
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Posted on Feb 18, 2010
POWERLESS /
Make sure you hooked up power ground and accessory. If you are connecting it just to make that it powers up, ut the yellow and red together and connect them to power at the battery. Connect the black to ground. Make sure the battery has power as well.
Aug 25, 2012 | Panasonic CQ-C8100U CD Player
How do i hook up my amp power wire to my panasonic cq-rx100u
Your power amp wire (positive (RED) ), should be hooked up directly to your battery....THe ground wire should be anchored to a bolt in your trunk (the short the distance the better), Make sure ground is getting a good bite on metal (no paint etc)....Only thing you should have hooked between your amp and radio is the rcas and your remote wire (blue).
Oct 07, 2010 | Panasonic CQ-RX100U Car CD/ MP3 Player
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
What color wire's do i match when installing and aftermarket deck into my 97 honda accord the deck is a panasonic CQ-C1303U
Sep 13, 2009 | Panasonic CQ-DFX701U CD Player
Ok everything is working but the remote wire not
First make sure you have the right wire hooked up, there is a Power Antenna wire, and remote turn on wire, and both are blue, but one has a white stripe.. Just make sure the right one is hooked up.
Now if the right wire is hooked up, and still no voltage there are 2 ways to get turn on power to the amp.
Option 1.
Buy a LVT (low voltage trip), they come with instructions, and arent very hard to use. They will only turn on the amp when signal is sensed through the speaker leads.
Option 2. (I don't care for this one)
Find an accessory fuse in the fuse box (meaning only has voltage when the key is in the on position), and run a wire from there directly to the amp.
WARNING ABOUT OPTION 2. This can be noisy, and cause a whine in your speakers, this should be a last option.
Aug 08, 2009 | Panasonic CQ-C8100U CD Player
Panasonic cq-dpx152u wiring diagram
Mar 11, 2009 | Panasonic CQ-DPX152U CD Player
Scooter stereo
As long as the battery is 12volts then it should be ok. Since you have verified that the yellow and red are wired to the positive terminal and the black is to ground, fuse blowing would indicate that there is an internal short in the unit. You need to open it up and follow the yellow wire where it leads to and check the surrounding components.
Does the fuse blow when just connected or when powering it up?
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Panasonic cq-c3100u
scottmar7- You need the wiring diagram for your panasonic deck,the diagram is as follows.
red- 12volt key switched
yellow-12volt constant-memory
black-ground
white-left front positive
white with black stripe-left front negative
grey- right front positive
grey w/black stripe-right front negative
green-rear left positive
green w/black stripe-rear left negative
purple-right rear positive
purple w/black stripe-right rear negative
blue- remote turn on- for amplifier
These are all the wires you should need,to hook up you deck.
If you need anything else let me know,I can help you,happy listening. cooltek mar,14/08
Mar 14, 2008 | Audio Players & Recorders
Panasonic CQ-C8100U CD Player Logo
32 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
