Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio won't reset print job
A print job received an error code 92 and now nothing else will print from the printer server. I tried resetting the job and it froze and took the printer offline and I tried resetting all jobs and nothing worked.
JackHeath
  • 1049 Answers
SOURCE: Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Posted on Jul 24, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error Log Cannot store data of this size. Document Server
The document server portion of the copier not only has limitations to it but it has compatiblity problems with it as well when dealing with mulitiple pages. The SODIMM card could be set for 64mb on your copier and the buffer is too small to work with it. It doesn't work the same way as a fiery server does on todays copiers.
Ricoh tech support has told me there are three ways to use the scanner:
1) Scan to e-mail.
2) Scan to ftp server.
3) Scan to document server using a seperate PC as the server.
4) Scan to a local computer using Desktop Binder.
www.ricoh-usa.com has software to do 3 and 4. #1 can be setup by adding the smtp server to your copier in the file interface section by pressing the user tools/counter. You have to have the IP address to the smtp server in order to get it to work. You can contact your internet provider to get that.
Using the document on the copier is for temporary storage and isn't designed to handle big jobs to it as well. You can experience storage problems as well if your print server is full or you are storing faxes to the memory.
The memory can be updated to the copier as well. It can read a SO DIMM PC100 card up to 256 MB. It's an older memory module that they use on older notebook computers. You can get them at computer stores or get them through PNY.com.
Posted on Aug 27, 2008
  • 126 Answers
SOURCE: How do I cancel a print job sent to the Ricoh
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
Posted on Jul 14, 2009
  • 68 Answers
SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Posted on Sep 16, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
Printer receiving data but does not print
are there any warning lights or message if not could be that print job has an error in file. check computers and clear any print job that is in que then turn copier off and back on and try a different file to print or try print a test page from printer proprieties.
Jan 14, 2014 | Ricoh Corp Aficio SP 6330N Laser Printer...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
On a ricoh aficio CL1000N, what does the error code SC922 or SC992 mean?
There is no sc922 for the CL1000N, but sc992 is a general software error. It typically shouldn't interrupt operation, but it if it does and it happens more than once, try to figure out what you were doing when it happened. Were you printing a big job? Were you printing a job with a particular font? Does it always happen at a certain time of day? Narrowing down the conditions can help to figure what is causing the error code.
Jun 30, 2010 | Ricoh Aficio CL1000N Printer
Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Mar 26, 2009 | Ricoh FT5832 Copier
Printing error log
reset the print jobs then check the printing refeperences.
Feb 08, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Unable to Print error
try resetting the print jobs from your computer printer que and also resetting all jobs from the printer side also good luck
Nov 08, 2008 | Ricoh Aficio SP-C210SF Printer
Error code 92
It sounds like the print job you are sending is probably on A4 and the machine is set to A4 or has A4 in the tray.
Try changing the page size that you send to the printer and ensure the paper size in the tray is the same as the print job AND that the tray sizes are set correctly.
Jun 18, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
105 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
