Question about Altec Lansing IMT702 inMotion MAX Portable Speaker System for iPhone
No sound on altec lansing imt702
Everything else seems to work ok there is just no sound. Ipod charges, radio, aux comes on but no sound
  • 18 Answers
SOURCE: altec lansing
I just got one used - which was billed as working fine but I got it and had the same problem - Ipod Classic or Nano needs to be pulled forward in order for it to connect with the Ipod. I can't tell if it's with the unit itself or a poorly designed connection that doesn't hit the right parts inside the Ipod - but it's definately the unit - 2 Ipods have the same problem.
My temporary "fix" was to use my leather Ipod classic case and wedge it between the Ipod and the im600. That gave just enough room - abou 1/2 inch - but it was soft enough and I could position it so it didn't block the IR for the remote.
I may try to buy some black or dark gray insulation material with a sticky back to it and attach it, a little bit at a time to build it up so that it has a support that positions it correctly, Kindof like creating a seat cushion to prop it forward.
If anyone else has a good fix let's hear it
Posted on Oct 17, 2009
SOURCE: Altec Lansing IMT702
http://www.youtube.com/watch?v=ztxvAAKhwU8
Posted on May 23, 2010
SOURCE: altec lansing speakers series 100 plugged in but sounds are distorted
I have to turn the volume to max to hear any sound. Up until now the speakers were great and only needed to be turned on slightly? any suggestions please?
Posted on Sep 12, 2010
  • 3 Answers
SOURCE: How to disassemble ipod docking station Altec
Remove silver side trim via 4 hex screws. The button strip and bezel assembly then easily lifts away. Unplug the connector on the right end to completely free the bezel.
Slowly and carefully pry front grill off by using a tiny jeweler's screwdriver, starting from the corners, and working your way around the sides and top (where trim and bezel will hide any plastic and grill gouging). It takes patience, gentleness, and lots of time to do it without damaging anything that will be seen. Eventually you can use a long flat blade to pry under the grill along the bottom, and where it wraps around iPod dock.
Use a very small jeweler's flat blade to pry out the 10 screw plugs that were under the grill. There's probably no way to get these out without gouging them, but the damage will be less obvious once the grill is back on. I even think it looks better to not have replaced the plugs.
Remove the 10 phillips head screws that were under the grill screw plugs, and also the 4 screws that were hidden by the bezel. Note that the two screws close to the LCD display are longer than all the others.
You do not need to remove the two screws that hold the back battery cover, in order to open the main unit.
Pry the two case halves apart with your fingers, held from the edges that were hidden by the silver side trim. There are various connectors and their adhesive dampening goo that will keep the case from completely separating.
To allow the two case halves to open more, hinging from the top collection of wires, it's helpful to release the iPod dock from the front half of the case. First, make sure the iPod dock is unlatched and in the out position. Note the two plastic pins on the sides of the dock carriage, that float around and are actually part of the latching mechanism as they run in the slots on the back half of the case. These pins can be pushed in so they are flush with the dock carriage's sides, allowing the carriage to slide out through the front of the unit. Just make sure they are swung out of the way of the slots on the front of the unit, or you won't be able to keep them pressed-in flush as they make their way through the front of the case.
Posted on Sep 19, 2010
  • 6 Answers
SOURCE: My Altec Lansing Inmotion used
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Posted on Jan 23, 2011
Need new adapter lost mine, got new one but 12v works but will not charge ?
Maplin Electronics have a good range of Power Adapters visit one of there shops.
Jul 16, 2013 | Altec Lansing Imt702 Im600 13v Ac Adapter...
How do I reset the imt702? I have no sound coming out of the device.
you tap the power button and source untill it shuts off and the power button on the left will be green.Then it should say reset and you hit the power button and the region will show and use + and -1to get your region usa 234 are for other counntrys like europe,japan etc. then power button again to save but mine still has no dam sound!
Feb 08, 2011 | Altec Lansing IMT702 inMotion MAX Portable...
Cannot hear sound when connected to ipod
http://www.landrover4hobby.com/phpBB/viewtopic.php?t=9126&sid=9d56c26ae52888a72d10ec81e014b340
These photos might help but I haven't tried it yet
My guess is its the docking connector - try pulling the ipod forward a a bit and see if that helps produce any sound. Look on these other threads for other discussions about that.
Sep 29, 2009 | Altec Lansing Inmotion-IM600...
Stops working after a few minutes
this problem name is dst plz change mark dc ic is working propery
Aug 25, 2009 | Altec Lansing iMT525
Need aux cables
Try your local pc shop or something like Radio Shack
Jul 11, 2009 | Altec Lansing ADA 885 Computer Speakers
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Altec Lansing IMT702 inMotion MAX Portable Speaker System for iPhone Logo
122 people viewed this question
Top Altec Lansing Cell Phones Experts
Computer Repairing
Computer Repairing
Tony Curto
Tony Curto
Lee K
Lee K
Level 1 Expert
Are you an Altec Lansing Cell Phone Expert? Answer questions, earn points and help others
