Question about Roper REX4634KQ Electric Dryer
Dryer belt routing for Roper Rex5634KQ1
Need dryer diagram for routing belt
tbirdfan1
  • 3051 Answers
SOURCE: looking for belt routing diagram for aroper
Helllo there:
Here is a listing of the routing diagrams for your dryer match the diagram to how yours is set up37db35f.gif
Posted on Oct 05, 2010
yalmer
  • 549 Answers
SOURCE: I have a Roper REX5634KQ1
Check to see if there is power coming to the outlet that it is plugged into.
It sounds like a fuse blew when you changed the light.
Maybe there is something wrong with the socket or the bulb you put in is bad.
If lyou have power to the dryer, then you must have a bad door switch etc.
Posted on Mar 22, 2008
SOURCE: Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Posted on Jul 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: roper dryer
One of them drum wheels is bad.To get to it: Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and inspect the wheels.
Posted on Dec 31, 2008
  • 105 Answers
SOURCE: I have a Roper Dryer Mod# REX5634KQ1. It just
There is a "one shot " thermostat that is probably blown. Part number 279816 which is a two piece kit. The part is located at the top of the heater housing.
Posted on Apr 07, 2009
Tip
Roper Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For models with non-removable back panels use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
on Mar 06, 2010 | Dryers
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
Roper Dryer REX5634KQ belt replacement
The manual will be no help in replacing your belt. It only tells you how to use the unit, not how to repair it. I have a copy of it in memory, if you'd like it email me your email address and I'll send it. I also have a diagram on file that shows the exact route for the belt on your dryer. I could send that as well. My email is fixitcr63@yahoo.com.
Dec 24, 2011 | Roper REX4634KQ Electric Dryer
Need belt diagram for Roper dryer RES 764 6KD2
this link http://www.repairclinic.com/Dryer-Belt-Diagrams is belt configuration of all different brank dryers,The roper is either going to be diagram H or K refer to chart to see which yours will be based on the back panel
Aug 21, 2011 | Roper Dryers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Roper Dryers
Looking for belt routing diagram for aroper rex3614kw1 dryer
Helllo there:
Jun 21, 2010 | Roper REX3614KW Electric Dryer
Apr 07, 2009 | Roper REX5635E Dryer
Trying to put belt back on dryer have know diagram
Follow the link to the belt diagram page and it will show you how to route the drum belt for your particular dryer.
http://www.repairclinic.com/0079.asp#DiagramK
Jun 08, 2008 | Roper Dryers
Roper REX4634KQ Electric Dryer Logo
234 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
