Question about HP Photosmart C7180 All-In-One InkJet Printer
Printing problem with HP C7180
When printing, repeatedly get an error message which causes the printing to stop and then the printer spits out page after page of garbage (letters, numbers, symbols, etc.) I then have the clear the print job both on the computer and on the printer before I can try again. There is no rhyme or reason to when it happens, but probably happens at least every third print job.
  • eastbay4 Dec 07, 2008
    I have a HP Photosmart C7180 All-In-One Printer Fax Scanner Copier, where the on-off switch worked sometime and not other times and then became recessed as my wife pushed the button harder and harder each time trying to get the C7180 turned on and off.
Posted on Oct 23, 2008
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Magenta white lines
ok , that is black nozeels , you have to change
Magenta printhead , please notify , do not stop printing while ,
I mean you should not stop printer for long time , that will cause
will dry ink that in side nozzels , and the problem will come again ,
mean you should print every day at least page one printout
Hope help you
Nov 25, 2012 | HP Photosmart C7180 All-In-One InkJet...
HI been using this printer HP C7180 All in One for 2 years great
completely Uninstall the drivers and reinstall drivers
Go to control panel Add/Rem and remove HP Software
Go To Control Panel
Click on System - Hardware - Device manager - Printers - Right click Uninstall (HP Printer Drivers)
Reinstall the drivers from the following link
HP PS C7180
Jan 07, 2010 | HP Photosmart C7180 All-In-One InkJet...
Printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart D7460 Error Message
Using an administrator account, remove HP Smart Web Printing using Control Panel - Add/Remove Programs.
If required, download and install HP Smart Web Printing from
(Thanks to Bellbird at
Nov 09, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
HP Deskjet 3820 states system error
try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
Mar 07, 2008 | HP DeskJet 3820 InkJet Printer
Problems Printing From Web
Download firefox mozilla & print from there ...It will be fine..
Otherwise you can download hp web smarting printing utility to correct web printing...
I will recomment you to print from mozilla
Dec 23, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
286 people viewed this question
Ben Johnson
