We just bought a Nikkai 2727 mini audio video sender kit and connected the skybox (in one room) to the transmitter, the TV (in another room) to the receiver, but the the tv says "no signal". Set the sender and the receiver on the same channel, but still does not work. What have I done wrong?
  • natalie_10 Feb 02, 2009
    I have exactly the same problem? There is just a blue screen and yet perfect sound?! So it seems as if there isn't a problem with signal? And yet i have no idea on how to solve it cus the scart leads seem fine
4 Suggested Answers
SOURCE: Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Posted on Feb 03, 2009
SOURCE: Nikkai 2727 Video sender will not send signals
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Posted on Feb 22, 2010
  • 3 Answers
SOURCE: I have a Nikkai A15gy
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Posted on May 18, 2011
How do video transmitters work?
A transmitter works by turning the audio/video device it is connected to into a audio and video signal broadcaster. So that when a receiver is connected to another device within range of the transmitter it will be able to pick up the signal from the transmitter and play on this second device. Say you have a TV in the family room and one in your bedroom, if you connect a transmitter to the one in the family room and a receiver to the one in the bedroom they will both be able to receive the same transmission.
Sep 08, 2013 | Televison & Video
I have just brought a nikkai 5.8 ghz audio/video sender so i can watch my sky in my bedroom but i am having real promblems with it i am getting no picture
I assume you have a 5.8Ghz receiver in your bedroom ? Your TV will not receive 5.8Ghz so you need a 5.8Ghz receiver in the bedroom that will give you an audio out and video out, which you connect into your TV audio in and video in .Put the TV on AV in and voila.
Apr 08, 2010 | Audio Players & Recorders
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
Jan 24, 2010 | Panasonic Televison & Video
Getting clear audio to televisions from a soundboard
I think you should buy a video sender. It will take audio from your audio console and send wireless to a free channel to any free TV channel. No cables!
Here's one on ebay:
http://cgi.ebay.com/Wireless-UHF-Audio-Video-Transmitter-Sender-4-Cable-TV_W0QQitemZ180307960679QQihZ008QQcategoryZ11726QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Nov 25, 2008 | Audio Players & Recorders
Nov 18, 2008 | Televison & Video
Need manual for nikkai a38fq car radio
I need the passcode for nikkai fm transmitter bluetooth thanks
Jul 29, 2008 | Audio Players & Recorders
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Jul 23, 2008 | Televison & Video
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
343 people viewed this question
Top Televison & Video Experts
Electro Med Services...
