Question about Frigidaire FRS23H7CS Side by Side Refrigerator
Water & ice dispenser
The water and ice dispenser in the door "stutters". When you try to get ice and or water it sometimes works but most the time just stutters. If you slam the door it "sometime' resumes working. I think it is a short but need help please. Thank you
  • Anonymous Jun 20, 2008
    Same problem. Took in apart, checked the connections, no change.
First unplug the refrigarator. Remove the plastic casing from above the left hand door. Usually the electical connections for the ice/water dispenser are under there along with the hinge fittings. Through time these connections can work loose. Ensure connections are in good order, refit plastic casing and try. This should take no more than 30 mins so should not casue a problem to refrigerator stock. Good luck.
Posted on Aug 03, 2006
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker and water dispenser
If the refrigerator water dispenser is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 06, 2014 | Samsung 33 in. W 24.7 cu. ft. French Door...
I have a samsung cool n cool american style fridge freezer with two tabs on the front. One for cool water and one for ice. The water works perfectly but no ice is being made to fill the bucket, why is
If the refrigerator water dispenser (or ice) is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Mar 30, 2014 | Samsung Refrigerators
The ice maker is not working right
replace the water valve and clean the coils undrer neath . ( make shure the fan under is working . mm
Jul 03, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water dispenser not working
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
Apr 26, 2007 | GE GSH25JFR Side by Side Refrigerator
Frigidaire FRS23H7CS Side by Side Refrigerator Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
