Question about Health & Beauty
How do you replace blade on paul mitchell clippers
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
geokohler
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
SOURCE: andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Posted on Nov 19, 2009
askmannyssha
  • 76 Answers
SOURCE: how do you change blades on Wahl's clippers?
No problem look at your clipper blade, you will see 3 screws remove the screw in the middle ONLY, The clipper blade will come off, replace with new blade put back the middle screw on and tighten.
Posted on Mar 30, 2010
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
May 29, 2010 | Andis 01690 Hair Trimmer
How do you change blades on Wahl's clippers? Have new blades dont know how to replace them.
Mar 14, 2010 | Wahl Designer 6 (8355100)
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
Cleaning Oster 78004-011 Clippers and blades
OK compressed air is perfect for your clipper, thats all it needs! Take the filters off (at the bottome of the clipper, either side of the cable) periodically and clear from excess fur. Replace. As far as the blades are concerened, Brush the excess furr off with a toothbrush or similar. Slide the cutter (smaller of the 2 blades) to one side (past half way but not all the way off!) clean exposed teeth on both blades with a bit of oil and a toothbrush, push the cutter the other way and repeat. Blade wash's tend to rust the blades, you need a big pot of WD-40. Get a 5 litre tub from the internet, only thing is there, postage will be a killer. I work for a clipper repair, blade sharpening company and we have it delivered by the truckload! Do what you do with the blade wash, but do it in WD-40. Wipe off excess afterwards and dont soak the clipper in any liquid because of electrc shock.
Thats all you can do! When your blades go blunt or clipper needs service repair: www.sheareaseltd.com If I have helped you please tell your friends about our website! Thank you!
Feb 25, 2009 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
293 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
