Question about D-Link Dlink DSL2320B
How do I reset it - tried rebooting, tried shutting if off. Can't get it to connect to mac
    Sergeant:
  • 233 Answers
If you dont have the appropriate driver for mac you still make use of ethernet functionallity on the router , just connect your MAC to the router with ethernet cable .make sure that your modem is configuerd as DHCP server .
Posted on Feb 08, 2012
My computer keeps shutting down irreglarly
Hey Henry,
Try reseting your PRAM and SMC.
Here's how to reset your PRAM:
  1. Shut down your machine. Yes, all the way down, not sleep or logging out.
  2. Press the power button and then press command-option-p-r. You have to make sure you get those keys pressed before the gray screen comes up or it won't work.
  3. Hold those keys down until your Mac reboots again and you here the startup chime.
  4. Let go of the keys and let your Mac reboot normally.
For SMC:
  1. Turn off your machine
  2. Keep the MagSafe adapter plugged in.
  3. Press at the same time shift-option-control (on the left side of the machine) and the power button
  4. Let go
  5. Turn your machine back on with the power button.
Nov 16, 2013 | Apple MacBook Pro Laptop Computer with...
I have got apple macbook pro unibody , my charger light is blinking and not charging battery while my laptop is on but when i shut down my laptop its connecting and disconnecting for 10 seconds interval
Try charging your laptop with a spare charger. If your laptop is still under warranty, make an appointment with a genius bar representative at a local Apple store to diagnose your laptop's issue and replace the charger.
Warning!
Do not use the USB ports to charge any external devices from your laptop! Instead use the chargers they were packaged with.
If the spare charger doesn't work after an hour of charging you will have to reset the System Management Controller with the Mac turned off:
Press Shift-Control-Option-Power key combination.
Release and press the power button.
If resetting the SMC doesn't work try resetting the PRAM. Keep in mind that you have to enter the key combination before the grey screen appears!
Reboot your laptop.
Immediately hold down Command-Option-P-R combination.
A reboot sound should confirm the reset.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
Fan won't stop
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
Hi i just purchased a D-Link DIR-412. I'm trying to login to http://192.168.0.1/ and the manual states to enter user=admin & leave the password blank. This is not working. I'm on a mac Os X,...
Did you capitalize Admin? It's capitalized in the manual, and user names are usually case sensitive.
If you can't get through the login process, you probably won't get the connectivity, either.
The manual says set the switch on the back to 3g mode during setup. After checking that, you might try using the RESET button on the back - while the router is powered, press and hold for 10 seconds and release. After the router restarts, reboot your computer and try connecting again.
May 02, 2017 | D-Link DIR-412 Mobile Broadband Wireless...
OK-so our mac computer is roughly 1 yr. old and its worked pretty great for the time we have had it but,one yesterday i turned i tried to get on the computer and it wouldn't turn on so i jiggled the...
The easiest way to resolve this problem should be to reset the SMC - System Management Controller - which deals with how power is distributed to various parts of your Mac, including the fans.
How to reset it depends on what kind of Mac you have, though.
For 'desktop' Macs, including iMac and Mac Pro:
  1. Shut down the computer.
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
If you have a portable with a battery you cannot remove:
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
If you have a portable with a battery you can remove:
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
That should take care of the problem. Good luck!
Jun 13, 2011 | Apple MB871LL/A Mac Desktop
I got an eMachine em350 today and it won't connect to my wireless, I've tried loads of things. Can you help me please?
power cycle the access point+modem
reboot the computer.
if that doesn't work, try going to search
look for cmd
right click and say run as administrator
type in netsh winsock reset then hit enter and reboot computer.
May 02, 2011 | Acer Computers & Internet
It shows message as "turn on camera" while try to
Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
b) Try resetting your SMC:
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
Dec 20, 2010 | Computers & Internet
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
D-Link Dlink DSL2320B Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
