Question about PfaFF Sewing Machines
Reset tension on pfaff grandquilter hobby 1200
I messed up the tension dial and can't find anywhere how to reset it to it's original settings. Arlene
  • PfaFF Master
  • 7,365 Answers
Check with sewvacdoctor.com
Posted on Feb 08, 2012
bargainbox
  • 1388 Answers
SOURCE: tention guide
It is normal for the tension to be relaxed when the presser foot is raised, so , is there any tension when the presser foot is down, even if only a little more ?
Check there is no lint built up between the tension plates as this is common, and will cause the tension to be affected as you describe.
Unusual but possible is that the lever mechanism which relaxes the tension from the presser foot to the tension dials is seized or "gummed up" with lint and old oil.........when was your last full service done ? If it was more then 2 or 3 years, just like a motor car, regular servicing will pay dividends in enhanced performance and longer life.
www.bargainbox.com.au
Posted on Mar 30, 2008
SOURCE: I have a brand new Pfaff GrandQuilter 18.8 and am
For a brand new machine, your dealer should help you get it set up properly and give you lessons. Every machine is slightly different. You may just have something as simply as an ill-fitted bobbin case or wrong needle inserted. If it is making a "banging" noise, don't force it to sew. Walk through your instruction manual step-by-step for threading and call your dealer for more help.
Posted on Oct 21, 2009
SOURCE: can not get thread tension on hobby 1200 grand
Adjusted the dial to the right until the stitches we better.
Posted on Dec 27, 2009
  • 16 Answers
SOURCE: TENSION IS MESSED UP ON MACHINE. WHAT ARE THE
The top tension dial is usually standard set on #3. The rest have nothing to do with tensions but make sure that your foot that you put the fabric under is up before you start threading the top
Posted on Jan 22, 2010
  • 1116 Answers
SOURCE: how to adjust lower tension on pfaff hobby 370
On the bobbin case is a screw. Mark the case with a tiny dab of nail polish and the edge of the screw. This will tell you where you began.
Turn the screw: right to tighten and left to loosen.
This is an adjustment that is usually not needed unless you are changing the weight of the thread being used on the bobbin.
Posted on Mar 13, 2010
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
Dec 10, 2015 | PfaFF Sewing Machines
Tension on my Pfaff Grandquilter
check carefully that the top thread is actually gong between the tension plates and not behind them and jamming on the retainer bolt
before threading the needle place the thread up to the point of threading the needle and pull on the thread , proper tension is when there is a slight resistance to pulling the thread
If it takes excessive force to pull the thread then it is caught around something so follow the thread all the way back to the spool to see where the problem is
May 21, 2017 | PfaFF Convertible Sewing Machines
Im looking for a user manual or instructions for my old pfaff Hobby 4260 sewing machine
Try this link (free download):  http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/Machinespage?OpenPage&Start=1&Count=400&Expand=76&ResortAscending=0&BaseTarget=RightFrame Good luck!
Mar 29, 2011 | PfaFF Hobby 4260
Pfaff Hobbylock 776
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
Sep 21, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
487 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
