Question about GE WJSR2070B Top Load Washer
GE Eight Cycle Washer (about 12 years old)
Thanks for your assistance. 1. This morning, my washer started leaking seriously. I opened up the back panel and discovered that a small hole in the basket (one of several) was leaking fast. As far as I could ascertain, none of the other holes were leaking. 2. Upon further inspection of the inside of the basket, I discovered a small, nail-like projectile (sharp as a nail) was projecting about 2" into the basket. I pulled on this but coiuld not draw it out of the basket. I wander what that is and how it got there. Sticking out, as it is, could rip delicate clothes during the wash cycle. And advice will be deeply appreciated. Capt. Donald Kilpela
    Top Expert:
  • GE Master
  • 50,588 Answers
Time to replace
Posted on Apr 03, 2017
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
dutchman05
  • 487 Answers
SOURCE: ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
SOURCE: GE top load Washer ripping clothes
I have the same GE washer with the ripping issues. I have had serviceman after serviceman out. They have continued to say I don't load the washer right or I overload. The last seviceman ordered the boot (seal) to be installed on my washer. That has been a little over a month ago and I have not had a ripping issue....fingers crossed!! I think GE is well aware of this problem and needs to do a major recall. This applicance does not live up the the cost. I have filed a claim with the GE claim dept and am going thru the process to get refunded on the clothes that were destroyed. I luckily had kept a lot of the clothes because I planned on writing a complaint letter. I have not received the reimbursement yet....we will see.
Posted on Jun 23, 2008
appldoctom
  • 311 Answers
SOURCE: GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Posted on Jan 01, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
My GE washer is stuck on a Stain cycle and it will not start. I can change the cycle, but it will not start and if I turn power off and on again, it goes back to Stain cycle. We've held the start/pause...
the G.E IS USUALLY RESET BY UNPLIGGING THE MACHINE A COUPLE MINUTES THEN PLUG IT BACK AND TURN THE ON KNOB TO ON THEN PULL OUT . THEN OPEN AND CLOSE THE LID SLIGHTLY) NOT ALL THE WAY JUST SLIGHTLY ) 6 TIMES WITHIN A 12 SECOND PERIOD , THIS SHOULD RESET THE WASHER IF IT DOESNT WORK THEN TRY THE SAME WITH THE KNOB ON THE OFF POSITION PUSHED IN
Feb 20, 2015 | GE Washing Machines
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
It will not turn on
Hello 90262
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, you have the blinking cycle light and it will not start.
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
How old is your washer???????????????
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Dec 15, 2007 | GE WCXR1070A
Ge washer overflowing/not rinsing or wringing well
if you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Mar 24, 2006 | GE WBSE3120B Top Load Washer
GE WJSR2070B Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
