Question about Technics SA-DA8 Receiver
SA8 5.1 receiver overload comes on with no sound
For a time I only heard sound on the left if I powered up then dropped back to normal listening levels. Now the overload comes on with no sound whatsoever. I removed all the incoming wires to see if there was one shorting out but no change. Is it worth fixing?
  • 86 Answers
Try checking your fuse if it overloaded then it probably blew it
Posted on Oct 22, 2008
Denton receiver shuts off when there is a loud sound from the show
Your Denon receiver may be going into overload, which comes from playing it too long, and too loud. Try reducing the volume to 1/2 your normal level. If you still have issues or questions, please visit my website at audioserviceclinic.com. Thank you.
Jul 09, 2012 | Denon AVR-3805 Receiver
Sansui 221 stereo receiver comes on, but no sound. Yes the wires are plugged into the receiver. When first turned on sound came through the speakers, then I noticed that the lighted back drop started to...
Since this receiver is old-school stereo-only from the pre-subwoofer-era HOW are you driving the sub? Please refer to ITS manual and connect it properly. The speaker outputs for this box are for single speakers only.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jun 24, 2011 | Sansui Audio Players & Recorders
I have an Onkyo TX SR505 receiver which for some reason, while watching TV or listening to music, there will be a click heard in the speakers and the sound will be gone. I'll shut off the receiver and turn...
It's probably self-protecting from heat build-up.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 19, 2011 | Onkyo TX-SR505 Receiver
My rx4103 receiver shuts off after 3 secs even before sound is heard what should i do
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Mar 20, 2011 | Sherwood RX-4103 Receiver
When it turn on it says overboard or no sound is heard. What it the problem?
"Overboard"?
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Check for loose speaker connections as a root cause for intermittent shutdown.
Mar 01, 2011 | JVC RX-554V Receiver
When watching a dvd or listening to music at a certain volume my receiver shuts down then when i turn it back on it says check speaker wires? how can i fix this problem?
You could follow its recommendations. Make sure they're not shorted and are tight.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 29, 2011 | Yamaha HTR-5790 Receiver
DVD Receiver: Model LH-T7652SA. When I switch on the machine, the sound comes on as normal (for eg the FM radio station), then after about 4-5 seconds, the sound cuts out completely. All the other...
Jan 21, 2011 | Audio Players & Recorders
Yamaha 5560 no sound from front left and right speakers. There is sound from center and back surround speakers.
hi,
just check by fault switched of the frond speakers. power on the receiver play some thing listen sound is coming from the other speaker except frond. press the speaker A button in frond of the receiver. listen is it become on. if not got to the menu of ur receiver surf for speaker configuration . find out the whether the frond speaker is off. if it off turn it on.
Dec 15, 2010 | Yamaha HTR-5560 Receiver
Rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Jan 06, 2008 | RCA RT2600 System
RE- WHIRLPOOL NO FROST REFRIGERATOR NOT WORKINK NEEDS SOME HELP
whirlpool has a problem with the relayoverload thats plugged into the compressor. unplug the frig for about 5 min. then, while standing behind it plug it back in and listen. if you here a hum then a click, then you need to replace the relay overload. remove the back panel. the relay overload it plugged in on the left side of the compressor. very easy to replace
Nov 28, 2007 | Whirlpool ED2FHEXN Side by Side...
Technics SA-DA8 Receiver Logo
425 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
